Strange character display on Profile
So this backwards apostrophe just appeared on the top line on the output display on the Profile. Restarted the console and it still appears. It stays there even with the console off and the surface still on. Any thoughts as to what the issue may be and how to clear it up? See picture below.
Re: Strange character display on Profile
hi Brian,
Does it go away if you turn on insert mode? (so other characters are displayed in the upper row). Otherwise you could try reloading the panel firmware, go to Options>Devices and control-shift right click on the right side of the Profile and choose "Download Main Firmware". If the character is permanently stuck you may need to replace the display. -Mike
Avid Live Sound Support |
When I turn on insert mode it does disappear, however, there is an "r" displayed instead of whatever number should be there. This was consistent no matter what channel or insert was selected.
I did as you recommended and downloaded the main firmware, and the problem did not go away. |
Display zoomed plug on Function key strike - Profile | JohnEvans | VENUE Live Sound Systems | 1 | 01-27-2014 03:58 AM |
strange display issue MC Mix (Euphonix) | nstu | Artist Series | 0 | 02-18-2012 06:03 AM |
I want the best possible mic with the most character | Infiltrator | General Discussion | 12 | 03-23-2011 08:46 PM |
Phoenix plug-in status display error on Profile | SteveGam | VENUE Live Sound Systems | 2 | 03-21-2008 08:15 PM |
Strange session state - display frozen, play/record strange | pkcraft | Pro Tools TDM Systems (Win) | 2 | 06-04-2007 02:43 PM |
