Old 05-24-2022, 12:01 PM
hoodwinked hoodwinked is offline
Default Changing track automation view via hotkey jumps to selected track
Just curious if other people have this bug as well. I have it on both Catalina and Big Sur using any version after 2021.3.1.
1.) Select a track somewhere in your session in the edit window.
2.) Scroll down so that selected track is out of view and put your edit selection on another track. Do not "select" the track like you did the first track that is now out of view.
3.) Use Ctrl + Cmd + Left/Right arrows to change the automation view
4.) It will change the automation view like its supposed to but then scroll your edit window to the track you had selected much like the "Scroll into view" option. Only workaround is to have "Link Track and Edit Selection" turned on all the time.
5.) This is not normal and Avid hasn't fixed it after 5 updates. Bravo.
Old 05-24-2022, 12:54 PM
BScout BScout is offline
Default Re: Changing track automation view via hotkey jumps to selected track
Do you have Eucon devices? (either the app on a phone/tablet or the hardware surfaces)
Old 05-24-2022, 01:10 PM
No, none at all. I can replicate this behavior over and over again as well as on my macbook running Catalina.
2021.3.1 does not do this. Every version after does.
Track View Toggle selected track on Dock dalonso66 Avid S1, S3, Dock and Control App 10 01-16-2018 08:28 PM
Track View Not Showing Waveform But its Selected randomdude84 Pro Tools 11 11 05-31-2016 08:35 AM
what's the kb and PC command for changing track's view vudoo Pro Tools TDM Systems (Mac) 7 02-09-2009 07:31 AM
Changing track view size DonaldM Tips & Tricks 3 06-26-2008 08:52 AM
Quick key for changing edit view to volume view in track? postman56 Pro Tools TDM Systems (Mac) 4 11-30-2007 10:56 AM
