Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-13-2022, 06:59 AM
HugoC HugoC is offline
Default Opening Session with lots of audio files takes too long
We are a film post production company and we have been having a problem for some time with sessions containing a lot of audio files. We create these sessions by importing all the rushes of a film in order to proceed to auto-conform later on. This is a lot of data.
We noticed that sessions took much longer to open from version 2020.9 onwards, for sessions created in version 2019.12. To give an order of magnitude, for a session containing 760 GB of rushes, it takes 1 minute to open in 2019.12 and 12 minutes in 2020.9 and beyond (we tested up to version 2021.12 and found the problem with each version).
The problem is even wider as importing audio files takes much longer than before. The files are simply added to the session, not copied.
We conducted tests in the same versions of Pro Tools, importing 160 GB of rushes. In 2019.12, importing audio files takes about 15 minutes, including the time to stamp the files with a new unique ID. In 2020.9 and beyond, we stopped the processes after 3 hours before they finished, so the files were not even imported into the session.
The files are stored in a USB 3.2 connected hard drive, and all the tests were done on this same drive. It is a Seagate BarraCuda 4Tb HDD (ST4000DM004). We work with these drives all the time, they are very fast and we never have any speed problems with them.
We ran these tests on :
- Version 2019.12: Mac Pro 5.1 with MacOS 10.12.6, 2x2.4Ghz Quad, 24GB RAM, GC ATI Radeon HD 5770 1024MB
- Version 2020.9 : Mac Pro 5.1 with MacOS 10.12.6, 2x2.4Ghz Quad, 48 Go RAM, GC Radeon RX 560 4Go
- Version 2021.12: Mac Pro 6.1 with MacOS 10.15.3, Intel Xeon E5 2.7 Ghz 12Core, 64 GB RAM, GC AMD FirePro D700 6GB, HDx 3
We would like to know if other film post-production studios are experiencing this kind of problem and if any solutions have been found, and also to alert Avid to the problem, so that a solution can be found.
Thank you very much and have a nice day!
Old 04-13-2022, 07:24 AM
BScout BScout is offline
Default Re: Opening Session with lots of audio files takes too long
Left out an important part: where are all these files stored? NAS, SAN, thunderbolt connected drive, internal drive?
Pro Tools changed the way they index and catalogued files between your versions. There are some tweaks that can be done depending on storage location.
Old 04-13-2022, 07:48 AM
Indeed, this is important information. The files are stored in a USB 3.2 connected hard drive, and all the tests were done on this same drive. It is a Seagate BarraCuda 4Tb HDD (ST4000DM004). We work with these drives all the time, they are very fast and we never have any speed problems with them.
I will edit the original post with this information.
Old 04-13-2022, 04:02 PM
As part of troubleshooting, I would take a session that you have been using and copy it to an internal drive(even the system drive will be okay if its an SSD) and see what happens
Old 04-13-2022, 04:31 PM
The Weed's Avatar
The Weed The Weed is offline
AFAIK, that's a 5,400 RPM. Was Disk Cache set to something in the older versions of Pro Tools and not the later versions?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-13-2022, 05:30 PM
Yes. Just not a drive I'd be doing anything performance critical on. That under spec slow drive may make differences between Pro Tools versions here much more significant.
And back to the OP
What file system is on the drive?
Lots of potential things to think about with troubleshooting. Disk Cache size already mentioned. And it's not just the size of the cache... but you should look at the amount of cache in use before and during the import and try to see if it's low and therefore maybe having to evict content from the cache. You will only see stuff load into the disk cache if you import clips to tracks. With content not moved you would hope only the header block is rewritten - It would not surprise me that Pro Tools might do some inefficient handling here. And just try with cache "normal" to see if it makes any difference.
How come you are importing this stuff on an external 5400 RPM drive and then not moving it during import? e.g. into the session folder on a fast SSD?
Have tried trashing prefs before each import and starting with sessions in exactly the same state (ie. totally empty, not from a template) before import?
You mention audio but is there video on the session and/or in the import?
If this is important you maybe also want to file an incident with Avid customer support, have them look over this with you, reporting it on DUC is unlikely to get something looked at by support/tracked as an incident or escalated to bug. If you already have an incident number posting it here may help get attention on it.
Old 04-14-2022, 06:56 PM
audiolex1 audiolex1 is offline
And back to the OP
USB 3.2 is meaningless if the drive is slow.
There are plenty of USB 3 drives with faster HDD drives that will perform way better.
Optimally, moving the SSD drives will change everything.
Old 04-19-2022, 02:37 AM
The file system is Mac OS extended (journaled).
As for the files, they are stored on the hard disk and we create the session on the same disk. We do not import video into these sessions. The audio files are not copied but just linked into the session. We don't want to copy or move these files, as this is usually several hundred GB of data, and moving/copying them would be very time consuming. We use these sessions to stamp the files with a unique ID so that the whole post production chain is sure to relink the right media to the right place, and also to auto-conform the rushes from the shoot.
Some in this thread mention that the discs used are too slow, however as I said in the original post, in earlier versions of Pro Tools we didn't have these problems with import speeds etc. So the problem is not with our disks.
We will test the solutions you give, but moving these sessions to internal SSDs or similar solutions would involve a big change in our workflow and significant costs for possible disk purchases, so we are hoping for a correction from avid.
Old 04-19-2022, 05:31 AM
That it worked OK before is unlikely to get anybody’s sympathy here when you are running on such a slow underspec drive. You are just very likely to be sensitive to changes that you would not be on a modern SSD. And you won’t know until you do more investigation.
Nobody from Avid is likely to be going to “correct” anything here, nobody has a clue what to correct. Avid staff may not even read this, this is not Avid customer support, it’s a user forum, if you want to reach support you need to file a support case. And the first thing they will likely note is you are running on an under spec audio HDD and likely ignore the case. So if nothing else reproduce the problem on a modern SSD and then file a support case with Avid.
Good SSDs cost ~$150/TB, hard to see that being a huge burden. And should be no burden at all, at least for testing/troubleshooting to see if that helps.
Old 04-19-2022, 12:30 PM
TOM@METRO's Avatar
^^^ this ^^^
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Save session takes a long time.......... mtung Pro Tools TDM Systems (Mac) 11 03-04-2010 04:25 PM
Opening a session or import a OMF takes a while ! bcoutre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-07-2008 01:26 PM
Computer takes to long to save / open session lotusstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-25-2008 10:27 PM
Changing from 1 Pro Tools Session to another takes too long jallen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-19-2007 05:06 PM
trouble opening session: can't locate audio files eddie v Pro Tools TDM Systems (Mac) 1 10-31-2003 09:44 AM
