Well, no fix for the S/PDIF problem and no output volume controls......
But seems to work just as before. |
What's the S/PDIF problem?
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
Kyle,
It's all in this thread . . . https://duc.avid.com/showthread.php?t=417551 and I've got a ticket open which Mark Corbin is dealing with. It's been handed to engineering. Dominic |
![]() Quote:
![]() Quote:
iMac 27 |
I’ve had the same problem often when I’m recording / over-dubbing a track…all is good when monitoring input ( DSP engaged and record enabled )… but when I disengage both the track- occasionally the plays back wildly out of sync.
My primitive response is to click/unclick the DSP and record enabled buttons a few times and it all starts playing back properly. A little annoying but only happens from time to time… And always corrects itself with a little fiddling… Last edited by darkwavo; 12-09-2021 at 01:05 AM. |
It's truly maddening. I have a ticket open as well. Got quick reach out from AVID, which I appreciate, but it's been kind of lumped with some other similar tickets and I don't think the session I sent will be examined.
They did have one suggestion that makes sense, but is impossible to work with - don't have any aux getting signal from anything that's not hybrid enabled when anything hybrid enabled is feeding it. Not possible. There are only 54 hybrid outs available... For anyone else: is the recording visually off-time in the timeline? Mine are between 1200 and 1900 samples early. Every take. I'll throw a little bit more time at it after my next session tonight, but then I have all-day sessions tomorrow and I'm super stressed about it. Everything is out of time. After tomorrow I will either have a workaround pinned down, or the Carbon is out. I can't afford throwing extra hours at it and the performers feeling like they play like **** because it's so out of time every playback. My setup is pretty straight forward - main, plus a headphone mix system fed from auxes. |
Yeah I would see things on the timeline, like at BAR 2, but on playback it would play milliseconds before bar two on a given track.
I sent all the files to Avid, engineering wrote back and said I was routing things wrong lol My sessions all start from a template, and the session they though I was routing wrong worked fine the next day. At the end, I was finding I had to keep both guitar (or vocal say, ) tracks in DSP mode or they'd be out of sync. So I was actually bouncing in place when they were playing back OK with the DSP buttons engaged. I just didn't have any more time to spend with it. Not for that money.
iMac 27 |
![]() Quote:
We've reproduced this issue (which appears to be the same I as Tom's). It's a very high priority issue and we're investigating a fix. We'll provide an update ASAP. Thanks for your patience.
![]() Quote:
I'm very sorry to hear you no longer have your Carbon unit. Last time we chatted it sounded like the issue was no longer occurring. As I mentioned above, we're investigating a fix now that we have a solid reproducible case. Apologies we weren't able to fix this earlier for you.
Carbon Phase issues with hardware inserts | alhardy | Pro Tools | Carbon | 4 | 12-30-2021 12:39 PM |
Sync Problems with Carbon Downstream | tomhartman | Pro Tools | Carbon | 7 | 07-01-2021 02:15 PM |
Using Carbon with Avid Sync HD? | akhafaji | Pro Tools | Carbon | 1 | 01-18-2021 12:03 AM |
Radar II sync to Pro Tools ***Solved*** | GuyPicks | Pro Tools TDM Systems (Mac) | 5 | 06-13-2008 09:04 AM |
