How 2 fix a circle?
I know how to get a loop/circle and I can record with that. If I stop, the circle disaper. I was seeking for some words, but maybe that was wrong, the seeking machines had no answer.
For example I wil play or record from bar 8 till 12. I set the beginning and the end. I hit play or record, and than I stop, and I want to play again from 8 till 12, but the beginning and the end is gone, and I have to set it again. Is there a possibility to fix it, until I deside to change it?
MacBook Pro Quad 2,3Ghz i7, 16GB Ram, 64Bit Pro Tools 2018-12, Logic X, Cubase 9.5 Eleven Rack |
Re: How 2 fix a circle?
Look up 2 things in the pt reference guide.
Timeline Insertion/Play Start Marker Follows Playback and Dynamic Transport I think between this 2 you will find your answer. If you have a selection and its looping and works then when you stop the loop point get res et or even not a loop anymore the start with Insertion follows playback as a topic to research in the reference guide, you'll find there is a button to turn that preference off and that may solve your problem.
Jay-J System MacPro 12 Core • 24 G Ram • 10.12.6 PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified 4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage MAXPower eSATA 6G Card • Wiebetech RTX100H-Q Kensington Trackball Works/Orbit Optical Bluetooth off/Airport on and off. |
Wonderful: "Dynamic Transport" (cmd + ctrl + P) is a solution.
The other is an option, but has some other sideeffects. Thank you very much.
SRS Circle Surround | EarHole | Post - Surround - Video | 17 | 03-20-2009 10:52 AM |
Something weird at the Circle K | jkess | Pro Tools TDM Systems (Mac) | 3 | 12-12-2007 03:36 AM |
Seventh Circle Audio | Punx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-17-2007 10:02 AM |
Seventh Circle N72 | Zetajazz44 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 12-10-2004 07:55 AM |
Seventh Circle N72 | bladesg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-27-2004 06:57 AM |
