Help! PT 9.0.5 won't even TRY to install on Mountain Lion
Hi everyone, I'm stuck.
I have a brand new Macbook Air, I can't get 9.0.5 to even begin to install — the installer icon bounces endlessly in the dock for a few minutes, and then stops bouncing but never does anything. I do have the System Prefs set to allow applications from anywhere, but no luck. I've installed several other applications (including Ableton Live Suite 8) with no problem. Once the installer stalls, Activity Monitor shows it using 0.0% CPU, and I've left it for quite a while to see if it ever would decide to do anything. As an aside: I have been running PT 9.0.6 quite fine on a 1.5 year old Macbook Pro, under Mountain Lion (and Lion before that). FYI the Pro had Lion when I got it, and I installed PT 9.0.5 and then upgraded to 9.0.6 before upgrading to Mountain Lion. This had me assuming I'd be able to run it on the new Air... Has anyone been able to install 9.0.5 on a clean Mountain Lion install? Any suggestions? This machine will be pretty useless to me if i can't run PT on it! thanks peter in oakland |
Re: Help! PT 9.0.5 won't even TRY to install on Mountain Lion
As its not officially supported thats why the complete installer won't work. It will only work if you have PT 9 installed before updating to ML. and then its not supported so could have issues with some scenarios or plugins etc. Either upgrade to PT 10.3 which is supported on ML or you could try connecting the mac pro via firewire and boot the laptop holding the T key and try to copy the PT9 files over. Chris
tell what it says. |
I am having the same problem. Have a MBP with mountain lion and had pro tools 9.0.5 on it yesterday but i was having issues so i uninstalled and was going to clean install and upgrade to 9.0.6 but now i cant get anything to install. Icon just bounces around.
Also like to add i tried two different full installers, both did the same thing.
unknowne0f84707cffc:~ KrisHeinold$ gdb test
-bash: gdb: command not found unknowne0f84707cffc:~ KrisHeinold$ |
skype me
I'm at our locker getting gear ready for a show on Saturday which i was going to record with my comp. Can you give any idea's on here? Or is the installer just not compatible? The 9.0.6 updater opened up fine but obviously couldn't find pro tools.
Have problem with Avid Forums Web Side on/off
Mountain Lion/PT Install/Ilok install problems | alex obradovic | macOS | 7 | 07-14-2013 06:19 PM |
ProTools LE 8 install fail on Mountain Lion; Using Mbox 2 Mini w/o installing PT | bjorkalie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-10-2013 06:35 AM |
Mountain Lion 10.8.2 original PTLE disk doesn't want to stay in the drive to install | cessnapilot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-12-2012 04:43 PM |
10.8 Mountain Lion Clean install? | nukepicnic | macOS | 5 | 09-27-2012 09:12 AM |
Install Mountain Lion on 1st Gen Mac Pro - Links | spearson8 | macOS | 1 | 09-25-2012 08:23 AM |
