Old 02-01-2013, 08:31 AM
TonyBuenger TonyBuenger is offline
Default Pro Tools HD Thunderbolt Native box and External Display
I'm new to the Apple/Mac world. Yes after many (20+) years on PCs I finally converted to a Mac system.
I have the MacBook Pro 15" mid-2012 connected to a Pro Tools HD Thunderbolt Native box (running PT 10 HD Native).
I'm using the "Thunderbolt Port" but isn't that the same port (mini display port?) that would be used to connect an external monitor?
I need to have the Pro Tools HD Thunderbolt Native box and external HDMI-capable LED monitor operating at the same time.
Old 02-01-2013, 08:35 AM
YYR123's Avatar
YYR123 YYR123 is offline
That's the beauty of TB right - all that stuff is daisy chainable
So u need a TB equipped monitor then right ??
Daniel
Old 02-01-2013, 08:42 AM
Default Re: Pro Tools HD Thunderbolt Native box and External Display
Yes. I'll be getting a TB-compatible monitor.
The Pro Tools HD Thunderbolt Native box has one port so it will be at the end of the chain.
I'm assuming the monitor will have two ports...one from the MacBook and one pass-thru.
Old 02-01-2013, 08:52 AM
nst7 nst7 is offline
The problem is that I think the only Thunderbolt display available is the Apple one, and I'm pretty sure it must be placed at the end of the chain as well.
Old 02-01-2013, 09:30 AM
thanks. Confusing...
http://reviews.cnet.com/8301-13727_7-20043524-263.html
Old 02-01-2013, 10:43 AM
Yes, out of luck.
Old 02-01-2013, 10:47 AM
clint bennett clint bennett is offline
Actually, incorrect.
The apple TB display has a second thunderbolt port on it to just that- daisy chain. Often I'm running a rig where my HD Native thunderbolt box is daisy chained after the monitor. Works perfectly.
Old 02-01-2013, 10:48 AM
Matts Matts is online now
Seems that the Thunderbolt display indeed has a Thunderbolt port for peripheral connections:
http://www.apple.com/displays/specs.html
"Peripheral connections
Three powered USB 2.0 ports
FireWire 800 port
Gigabit Ethernet port
Thunderbolt port
Kensington security slot"
-matts
Old 02-01-2013, 11:21 AM
FireWire 800 port
Thunderbolt port
-matts
Excellent. Thanks
Old 03-30-2013, 04:01 AM
Actionmusic Actionmusic is offline
I have an IMAC 2.8 2011, the i7 upgrade model which i presume will work with Native thunderbolt. The Imac only has one thunderbolt output and the native thunderbolt box doesn't have a thru. So how can i without buying an apple monitor run my second non- thunderbolt LCD monitor in this setup?
I unplugged my thunderbolt display and no more Pro Tools errors! Brettster Tips & Tricks 12 02-19-2014 05:38 AM
HD native thunderbolt through Echo Express SE Thunderbolt Chassis hkj1 Pro Tools HDX & HD Native Systems (Mac) 1 11-06-2013 05:49 PM
Native Card vs Thunderbolt external brickroadstudio Pro Tools HDX & HD Native Systems (Mac) 1 09-28-2012 01:17 AM
Pro Tools HD Native Thunderbolt Tweakhead Pro Tools 10 35 09-11-2012 10:00 PM
External Thunderbolt display Affecting performance on MBP Quad EDurney macOS 4 12-13-2011 03:37 AM
