Old 10-18-2023, 08:55 AM
rain productions rain productions is offline
Default Eucon Software doesn't recognise Artist Control
I've changed my Mac from 2013 Mac Pro to M2 Mac Studio. I can no longer use my Artist Control with the new Mac Studio. The Eucon control software doesn't recognise it. I use Mac OS Ventura, Pro Tools 2023.6 and Eucon 2023.6. I have already changed the hostname of the Mac Studio. I also use an Avid Carbon plugged into the ethernet port. So, I use an adapter (TB to Ethernet) for the Artist Control. However, I tried also to plug it directly into the ethernet port with the carbon discarded. Same problem. Can anybody help?
Old 10-19-2023, 09:04 AM
EddieJones's Avatar
Default Re: Eucon Software doesn't recognise Artist Control
In Avid Control top left is there a red exclamation mark?
Make sure the versions are the same for AC and EuControl
What IP addresses are the tablet and the Ethernet adapter?
Old 10-20-2023, 06:18 AM
Hi Eddie,
Thanks for your answer, but you misunderstood me.
I'm not talking about Avid Control, I'm talking about the Faderbox Artist Control:
https://www.gear4music.be/de/Keyboar...ontrol-v2/17BI
It's not recognised anymore.
Old 10-21-2023, 05:41 AM
Mark Ziebarth Mark Ziebarth is offline
I guess your problem is this device is obsolete and not supported by newer versions of EU Control.
Best, Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 10-23-2023, 05:29 AM
I understand this page like this: The software still works but the device is no longer sold and there are no more spare parts.
Or does the current Econ software no longer work with the Artist series?
https://www.avid.com/de/resource-cen...ntrol-surfaces
Old 10-23-2023, 08:23 AM
BScout BScout is offline
You understand correctly.
The Artist Series still works with the current version of Eucontrol. If it isn’t showing up as a possible surface, there is some other issue.
Did you set up the Artist controller with a static IP? Reset the unit to use dhcp.
Old 10-23-2023, 08:52 AM
I found it 😊.
I had to change the network connection in the Apple System Preferences. There is an extra tab for Eucon. There you can select your network connection and I had to change it from USB to Thunderbolt.
Thanks for your help anyway.
PT 2021.10 No Go on Mac 5,1 with Eucon & Artist control TommyT Pro Tools 13 11-01-2021 01:55 PM
Eucon 3 - Artist Control not connecting to PT Trazan Artist Series 50 04-04-2016 03:14 AM
ATTN JC. Eucon 2.7 + Artist Mix/Control via HUI Herbieoz Artist Series 5 01-09-2015 02:14 AM
Eucon, Artist Control and mouse. vinnyburns Artist Series 6 04-16-2014 06:43 PM
Artist Control not working with Eucon 3 on OS X 10.8.4 Jerry Woolsey Artist Series 1 06-24-2013 01:21 AM
