Old 11-11-2018, 03:36 PM
ramonetl ramonetl is offline
Default Fixed: No input signal? PT2018.10 and UAD Apollo TB2 units
Recently I backed up my system and upgraded to Mojave knowing that while PT was not yet certified, I could always roll back and I am daring that way. I did it first on my mbpro and let it run a week or so before I committed to doing this on my mac pro. I did deal with the gotchas of getting my eucon stuff all working and PT played my sessions back nicely so i thought ok all good. However today I discovered that I may have the worst kind of bug in that I can get no input signal from my apollo 8p quad or my Twin quad. The session plays back just fine and so I did the usual blow away the io and reset to default. Then I started trying different inputs from spdif (kemper) to Apollo 8p channel one then the twin channel one. None get a signal input no matter what I try or what input I select. Its showing a strong signal in the UAD console and playback from PT to UAD console shows and is controlled as well. Has anyone come across this? I would like to try to fix this before I roll back. Please dont just say you should never upgrade til avid says its supported because that I know but someone has to find and fix these issues. :) I did go download the latest 9.7 UAD update but that didnt do anything here. It appears to be within ProTools. Thanks for your time. Peter
Old 11-11-2018, 03:51 PM
jjnssn jjnssn is offline
Default No input signal bug? PT2018.10 and UAD Apollo TB2 units
Check UADs site about Mojave. It should work. I upgraded and it had worked so it isn’t clear why it isn’t for you.
Old 11-11-2018, 03:58 PM
Default Re: No input signal bug? PT2018.10 and UAD Apollo TB2 units
Dude you are the best! It turned out that I needed to enable the microphone for ProTools. When I looked up the article you referenced they had a picture of that and I looked and sure enough it was not selected. Thanks for pointing me in the right direction. Peter
Old 11-11-2018, 04:40 PM
Default Re: Fixed: No input signal? PT2018.10 and UAD Apollo TB2 units
Awesome.
Old 11-13-2018, 09:48 AM
climber climber is offline
Apparently for OSX versions above Sierra you must enable the microphone input in the Settings to be able to record. I updated to Mojave, had the same issue and I'd never heard this. Changing it immediately resolved that issue.
Why isn't this prominently noted somewhere? Or is it & I just missed it.
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 11-14-2018, 02:22 PM
I had never experienced this before either. It annoyed me but at least once I saw the pic from the UAD article I got it fixed right away. I think this is more apple locking down how things get access but yeah Avid should give you a popup to enable it...
External Hardware with PT2018 and Uad Apollo [solved] spock999 Pro Tools 2018 1 03-08-2018 02:37 PM
2x Apollo interfaces, only input from 1 ShortWarning Pro Tools 12 5 08-03-2017 07:19 PM
Pro Tools 12.5.2 Simply not Getting Input Signals from Apollo sandcastle Pro Tools 12 2 09-24-2016 03:43 PM
No Signal from UA Apollo Twin fpalmieri macOS 21 05-07-2015 09:52 PM
Win 7 - UA Apollo working, with Digidesign 003 as Midi input Tripledweb Windows 2 03-17-2013 08:48 PM
