changing edit window track size?
is there a way to change the size of the tracks in the edit (CORRECTION MIX) window? depending on how i set up the interface, 11R, digi I/O, or other firewire interface, i get a good sized edit (correction MIX) window and other times, i get a small one.
for example, on a good sized window, a stereo track shows me the numbers for panning left and right. on my reduced sized window, i only get the knobs. no numbers... i really want those numbers and i can't seem to figure this out. i'm comfortable with pro tools, but never had an issue with PT8LE. (edit: i guess not comfortable enough to know the difference in names between the edit window and the mix window. ha ha ha!) what is this? any help? here's a pic. hopefully this explains it better than i did! http://oi54.tinypic.com/dd007r.jpg |
Re: changing edit window track size?
your picture is of the Mixer window, not the edit window... So, to toggle Large Mixer / Small Mixer, Hit Option + Command + M with a track selected.
In the edit window, you can drag a track to any size you like PT 7.4+ Edit: HD2 BEAT ME TO IT
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
OOPS! how embarrassing!
i meant the mix window. thank you for the response. it was exactly what i was looking for. |
Changing fader size in mix window | remusjacobs | Pro Tools 10 | 2 | 09-16-2012 03:11 AM |
Changing Edit Window Colors To Look More Like Logic 8? (PT8 Skinnable?). | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-30-2009 06:35 AM |
Can't re-size Structure edit window | Big World | Virtual Instruments | 15 | 10-23-2008 04:18 PM |
Mix and Edit Window size | louisenslinproduce | Pro Tools TDM Systems (Mac) | 4 | 01-12-2008 08:52 PM |
Changing Fader Size in Mix Window | WizDoomBorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-13-2005 04:27 PM |
