Re: Pro Tools SE White Noise - Is there a solution?
I bought this M-Audio fast track pro a week ago and I had the same problem with this white noise in background of my work. I tried what ever you think and suddenly I found the solution. follow these steps: 1- turn on your pc/laptop 2- plug in the USE cable from m-audio to your pc 3- turn m-audio on 4- here you can see white noise 5- turn off m-audio 6- unplug it from pc 7- put your pc on sleep, DO NOT TURN IT OFF OR RESTART IT (just close the lid or press the power button one time or from start menu>Sleep) 8- wake the pc up 9- plug in the USB cable 10- Turn on m-audio Here you are... White noise is gone... the reason could be over load of usb voltage regulators. (it is not a hardware/software problem, in medicine we call in congenital problem :) ) I hope it works for you too. I tried this method more than 10 times and it works good. good luck. enjoy m-audio |
I think the static might have something to do with the interface that is being used with the software. Pro Tools uses the interface for the output audio as well. So you have data going in and out through the interface. I have a Fast Track and the USB is a 1.1 which is clocked at only 12Mbits/second. I have used it with Adobe Audition as well and although the static is not as bad as Pro Tools it is still there. I am dumping the Fast Track and going with something that has a USB 2.0 which has a raw data rate at 480Mbps. And even though it won't top out at 480 it is way better than the 12 USB 1.1 delivers
Experiencing the same problem as Op!
My Setup: Dell Inspiron 1525 Win Xp Pro sp3 Intel core duo 2.00Ghz 3 Gig Ram 7200 rpm internal Hard Disk M-audio Fast Track & Fast Track Pro(latest drivers from M-audio web site) Please get us a patch to fix this asap. Tommy |
There are a variety of things on a Windows system that can cause disruptions like this in the audio. Have you followed the suggestions here to try and isolate the problem?
Pops, clicks, crackles, dropouts, or distortion – USB Audio Troubleshooting Guide |
Ive tried everything i can this static is kind of frustrating. its a clean instrumental and its a clean vocal track but sometimes when i play it back it just gets a really loud static that ruins the whole thing. its will come on and stays there for a while, itll go away after pushing play and stop a bunch of times, but it comes back almost right away. i know that i recorded it clean and i know the instrumental is clean. I might return this product if i cant find a solution. what do i do? Im in need of some serious help.
#16
not sure if this has been covered but the best way to rid this problem is to undo running programs not needed in msconfig. i only start what is nessesary and leave anything not needed not running. also DISABLE WIFI AND ANTIVIRUS! thats a given though but some dont understand. there are good guidelines to tweak you OS for pro tools and most work great. hope this helps.
#17
Is there any progress on SE compatibility with Windows 7 ??
White Noise, distortion, pops, loud noise in Pro tools 9 and mbox mini | Bigpit | Windows | 1 | 09-09-2013 09:26 AM |
Pro Tools SE white noise solution | Dcader10 | Pro Tools SE and Essential (Win) | 1 | 10-09-2012 09:13 AM |
White noise Pro Tools LE | tuzzound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-21-2011 11:10 PM |
static white noise solution | craigyj | Pro Tools SE and Essential (Win) | 2 | 02-21-2011 12:06 PM |
"White Noise" M-Box + Pro Tools LE | Craig1982 | Pro Tools M-Powered (Win) | 2 | 10-06-2005 10:19 AM |
