Re: Distorted sound (intermittent) on playback
I used to get this using a M-Audio Delta 1010L and M-Powered 8 (full version) If your talking a slight distortion in the audio, and not a blast of deafening white noise. What fixed it for me was to disable C1E in the computer BIOS. Google C1E and what it does and if you can disable it on your computer. Also make sure your processor is set for 100 % min/max. You can find a lot of useful information Here. That info would pertain to any DAW no matter the scale.
My computer specs:
Still getting distortion after about 3 min of playback. (tunes playback OK on Itunes) Samsung Laptop R580 win 7 64bit 4 gig ram Intel core i5 2.27 hz M-430 100G HD, 18G free External HD 350G....session files run from here. No strange alterations from stock. Proman |
Here are my computer specs.
Still having the intermittent distortion on playback . Short tunes (sessions), 4 tracks, no fancy effects, etc. Is there some sort of update version for Pro Tools se? It certainly appears others are getting the same distortion (white noise, static)....tho I haven;t read about any solid resolve. Samsung R580 laptop 4 gig ram Intel Core i5 2.27 ghz win 7 100g HD, 18G free have external 500g HD attached, sessions run from this. Note: sessions (tunes) run fine on Itunes. Hope this info can lead to a fix. Proman |
Hi ProMan. Thanks for posting the computer specifications. We are looking into this issue which may take some time, but we will post information on the forum as it becomes available.
Product Designer Avid |
I had badly distorted sound on playback Mbox 2 Mini- crackling sound like somebody flicking through a deck of cards. This was cured by setting the Setup>Playback Engine>Hardware Buffer Size = 2048 Samples. My OS is Windows 7 64 bit, Proc is Intel i7.
R |
#16
Experiencing the same thing as Op!
My Setup: Dell Inspiron 1525 Win Xp Pro sp3 Intel core duo 2.00Ghz 3 Gig Ram 7200 rpm internal Hard Disk M-audio Fast Track & Fast Track Pro(latest drivers from M-audio web site) |
#17
rvss3ll, in Protools Se we don't have the option to change the buffer like in Mpowered. Le, or PT9 we only have an option that does it for us to a set amount, but changing it doesn't help.
Tommy |
#18
From the "Help us help you sticky" :
Windows users need to provide a Sandra report - Please - Use SiSoftware's Sandra Lite application to generate a full system profile: www.sisoftware.co.uk Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC. This will give the most useful information to get a resolution. |
Distorted Playback for all sound | Seangleeson1 | Windows | 0 | 07-05-2012 07:25 AM |
Distorted Sound on Playback & Interference in Phones | DMS503 | Pro Tools SE and Essential (Win) | 1 | 09-07-2011 06:56 PM |
Distorted Sound In Playback | steverido | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 01-19-2010 08:05 AM |
Intermittent playback | mcfly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-14-2008 03:53 AM |
Intermittent Playback through M-Box 2 mini | Sadie Tango | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-25-2006 05:46 PM |
