Please help me with fast track+essential
HI EVERYONE,
YESTERDAY I BOGUHT THE NEW FAST TRACK MKII.. I'VE INSTALLED IT ON A PC RUNNIN' WINDOWS XP PROFESSIONAL SP3. I'VE BEEN TRYED INTERNET DRIVER AN CD'S TOO. EVERYTHING IS OK I CAN HEAR MUSIC FROM IT... BUT THE BIG PROBLEM IS THAT AFTER I'VE INSTALLED PRO TOOLS M-POWERED ESSENTIAL , WHEN I TRY TO OPEN IT I GET A MESSAGE IT SAYS: UNABLE TO FIND YOUR M-AUDIO HARDWARE, PLEASE MAKE SURE IT'S CONNECTED AND TURN IT ON!!!! HEEEEEEEEEEEEEELP I CAN'T OPEN PRO TOOLS!!! SOUNDCARD IS PERFECTLY WORKING AND TURNED ON....WHY I GET THAT KIND OF ERROR??? HEEEEEELP HEEEEEELP PLEASE... |
Re: Please help me with fast track+essential
Check the M-Audio Control Panel to see if it recognizes the device as "connected": http://www.m-audio.com/index.php?do=...088cda91d578da
thank you very much!!!
i've tryed everything you told me but i can't open pro tools m powered 8 still... my windows xp says connected but when i click on pro tools i still get the same error.... i don't know what to do.... |
here' my report....please help me i'm goin' crazy!!!!
actually is in italian but i hope you can understand it anyway...thanks Sistema Modello : System manufacturer System Product Name Workgroup : WORKGROUP Nome Host : sal Utente : Sal84 Processore Modello : AMD Phenom(tm) 9550 Quad-Core Processor Velocità : 2.2GHz Core per Processore : 4 Unità Thread per Core : 1 Unità Tipo : Quad-Core Cache Dati Interna : 4x 64kB, Sincrono, Write-Back, 2-way set, Exclusivo, 64 byte line size Cache L2 On-board : 4x 512kB, ECC, Sincrono, Write-Back, 16-way set, Exclusivo, 64 byte line size Cache L3 On-board : 2MB, ECC, Sincrono, Write-Back, 32-way set, 64 byte line size, 4 thread condivisi Sistema Mainboard : Asus M3A78-EMH HDMI BIOS Sistema : American Megatrends Inc. 0902 04/22/2008 Bus : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Supporto MP : No MP APIC : Sì Memoria Totale : 3.25GB DIMM DDR2 Chipset Modello : ASUS RS780 Host Bridge Velocità Front Side Bus (FSB) : 2x 1.8GHz (3.6GHz) Velocità Bus di Memoria : 2x 100MHz (200MHz) Chipset Modello : AMD F10h Athlon 64/Opteron/Sempron HT Hub Velocità Front Side Bus (FSB) : 2x 1.8GHz (3.6GHz) Memoria Totale : 4GB DIMM DDR2 Velocità Bus di Memoria : 2x 400MHz (800MHz) Moduli di Memoria Modulo di Memoria : A-Data DQVE1A08 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Modulo di Memoria : A-Data DQVE1A08 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Modulo di Memoria : Aeneon AET760UD00-25DB97X 1GB DIMM DDR2 PC2-6400U DDR2-800 (4-5-5-18 3-23-6-3) Modulo di Memoria : Aeneon AET760UD00-25DB97X 1GB DIMM DDR2 PC2-6400U DDR2-800 (4-5-5-18 3-23-6-3) Sistema Video Adattatore Video : NVIDIA GeForce 9600 GT (64 SP 1.6GHz, 1GB DDR3 2x800MHz, PCIe 2.00 x16) Processore Grafico (GPU) Adattatore : NVIDIA GeForce 9600 GT (64SP 1.6GHz, 1023.7MB 2x800MHz, Grafica Integrata) Unità di Memorizzazione Fisiche MAXTOR STM3250310AS 250GB (SATA150, NCQ, 8MB Cache) : 233GB (C:) WDC WD5000AAKS-00A7B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (E:) Generic-Compact Flash (USB) : N/A (G:) Disco (USB/SATA2400, 37kB Cache) : N/A (H:) Generic-SD/MMC (USB) : N/A (I:) 0AS (USB/SATA2400, 25460rpm, 10MB Cache) : N/A (J:) HL-DT-ST DVDRAM GH22NS40 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) TSSTcorpCD/DVDW SH-S182D (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) EHUNST O5UZ0TIF (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (K:) Unità di Memorizzazione Logiche Disco Rigido (C:) : 233GB (NTFS) @ MAXTOR STM3250310AS 250GB (SATA150, NCQ, 8MB Cache) Disco Rigido (E:) : 466GB (NTFS) @ WDC WD5000AAKS-00A7B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) CD-ROM/DVD (F:) : N/A @ HL-DT-ST DVDRAM GH22NS40 (SATA150, DVD+-RW, CD-RW, 2MB Cache) CD-ROM/DVD (D:) : N/A @ TSSTcorpCD/DVDW SH-S182D (ATA33, DVD+-RW, CD-RW, 2MB Cache) CD-ROM/DVD (K:) : N/A @ EHUNST O5UZ0TIF (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) Unità Rimovibile (G:) : N/A @ MAXTOR STM3250310AS (USB/SATA150, NCQ, 23kB Cache) Unità Rimovibile (H:) : N/A @ Disco (USB/SATA4800, 18028rpm) Unità Rimovibile (I:) : N/A @ TM3250310AS (USB/SATA9600, 8224rpm, 9MB Cache) Unità Rimovibile (J:) : N/A @ ¦^86^86 (USB/ATA100, 18028rpm, 23kB Cache) Periferiche Controller LPC Hub 1 : ASUS IXP SB600 SMBUS Controller Controller LPC Hub 2 : ASUS SB700 LPC host controller Controller Legacy LPC 1 : ITE IT8712F Periferica Audio : ASUS IXP SB600 High Definition Audio Controller Codec Audio : Realtek Semiconductor 883 High Definition Audio Porte Seriali : 1 Porte Parallele : 1 Controller Disco : ASUS SB700 SATA Controller [IDE mode] Controller Disco : ASUS SB700 IDE Controller USB 1 : ASUS SB700 USB OHCI0 Controller Controller USB 2 : ASUS SB700 USB OHCI1 Controller Controller USB 3 : ASUS SB700 USB EHCI Controller Controller USB 4 : ASUS SB700 USB OHCI0 Controller Controller USB 5 : ASUS SB700 USB OHCI1 Controller Controller USB 6 : ASUS SB700 USB EHCI Controller Controller USB 7 : ASUS SB700 USB OHCI2 Controller Controller FireWire/1394 1 : VIA VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller Controller di Sistema SMBus 1 : ATI SB600 SMBus Controller di Sistema SMBus 2 : ATI AFS SMBus Stampanti e Fax Stampante : Microsoft XPS Document Writer (600x600, Gestione colori immagine) Servizi di Networking Adattatori di Rete : HNWU254G Wireless Adapter #2 - Miniport dell'Utilità di pianificazione pacchetti (Ethernet, 54Mbps) Risparmio Energetico Stato Alimentazione Esterna : In linea Sistema Operativo Sistema Windows : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Conformità della piattaforma : x86 Suggerimenti per migliorare le prestazioni Attenzione 100 : Per sistemi con grandi quantitativi di memoria si consiglia l'utilizzo di moduli Registrati/Bufferizzati. Suggerimento 2546 : Moduli di memoria ad ampio taglio dovrebbero essere con ECC/Parità. Suggerimento 2 : Doppio clic sul suggerimento o premere Invio quando un suggerimento è stato selezionato per avere ulteriori informazioni. |
First make sure you close every other application running on the pc, then try opening pro tools again.
Try disabling the onboard soundcard (or whatever original soundcard that you had before) from the control panel or the device manager (if you know how to do that). If that doesn't work, did you try re-installing pro tools ? maybe try a different location for the install. do you have the latest drivers for the "Fast Track USB" from http://www.m-audio.com/index.php?do=...drivers&f=1028 ? try reinstalling them. Try changing the usb port your using on your pc see if that does change anything. Restart your pc. Anyways I just baught mine a few days ago too and its working fine (windows vista sp2). good luck |
it's probably obvious but the software will only open when your actual interface is connected via usb. Otherwise you will get that exact message.
Try another usb port if it is indeed connected when you have that problem. |
hey guys i've tryed to reinstall pro tools lot's of times, so i decide to install m-powered 8 full and i get the same error....i've cleaned up my pc...i've reinstalled windows too with no original soundcard's driver and i get the same error...i think i've switched to every usb port but nothing....there's no solution....
i've installed the driver on my laptop (windows vista home premium sp2) and it works fine i get no errors .....at the moment i only can say that fast track mkII doesn't work with windows xp........i repeat i've formatted my hd too and reinstalled fast track and pro tools too but nothing... thanks guys |
on the about tab of the Fast Track control panel, what is the audio driver version number?
Do you have Internet Explorer 8 installed? |
i don't have ie8...i didn't install it....i have 7
the version of the driver is the last one i dowloaded form m-audio support center : panel 1.0.2.1... thanks |
What is the audio version though? 5.1.??? 5128v4 is the latest driver for XP SP3. I just tested with that driver and PTE opens. If you have a previous version, make sure you select Windows XP SP3 when downloading the driver from the site.
New PT10 User. MBox3, MAudio Fast Track Ultra, MAudio Fast Track 8R? | epu | Pro Tools 10 | 3 | 06-13-2012 03:55 PM |
PT9 + Fast Track Pro, once track record enabled,gets very choppy. | Babiker | Windows | 1 | 04-04-2012 01:19 PM |
Pro Tools M-Powered Essential trying to add mp3 track please help! | eddiebrumley | Pro Tools M-Powered (Win) | 0 | 07-16-2011 01:23 PM |
Check the box before buying Fast Track Version of PT Essential! | bilco | Pro Tools SE and Essential (Mac) | 14 | 02-09-2010 05:50 PM |
Fast Track M-Powered Essential | rhendee | Pro Tools M-Powered (Win) | 2 | 11-11-2009 02:00 PM |
