Old 09-11-2007, 10:56 PM
robersl robersl is offline
Default Groove/Quantize Assertion error
When I attempt to select a Quantize Grid under Grid/Groove Quantize, I get an Assertion error for FileLoc.cpp, line 89.
I have gone through the delete databases and preferences treatment twice, but this does not remedy the problem.
I have Googled the DUC, the internet, and anything else I can find to Google, but I can not find any discussion of this error.
Has anyone else seen this problem? Any advise/help would be greatly appreciated.
Thanks,
Steve
Old 09-12-2007, 11:00 AM
timebandit timebandit is offline
Default Re: Groove/Quantize Assertion error
I had a similar problem when I closed a session with 'groove clipboard' selected as the source of the groove quantize file. Upon reopening the session I got the assertion error and could not re-select a different groove file as the source.
I saw mention on the digi support site as a 'known issue' but have not seen nor heard of a resolution. I can not groove quantize that session anymore! Since then I always make sure to change back from the 'clipboard' (if I use it) before closing a session.
Not much help, but you're not alone!
Tom
Tom Lynn
my music:
www.tomlynnmusic.com
other people's music:
www.headphonomenon.com
Old 09-12-2007, 01:40 PM
Thanks for the response Tom.
It hadn't occurred to me that this might be session specific. I'll try opening a different session and see if it works there.
Steve
Old 09-14-2007, 09:12 AM
As follow-up, for anyone searching the DUC for this problem in the future, let me tell you what I did to solve this issue.
I went into a different session, and, just as Tom implied, this was a session-specific problem. The Groove/Quantize assertion error did not occur in the second session.
I selected a different pattern from the one that came up, then canceled out of Groove/Quantize and closed the session.
I then went into the session in which I had been getting the assertion error, and the problem had disappeared.
Steve
javascript:void(0)
Old 09-14-2007, 09:55 AM
Thanks for the update...I never had occasion to notice the assertion didn't come up again on the original session. Good to know.
Tom
Tom Lynn
my music:
Assertion Errors Elastic Audio Quantize to Extracted Groove PookaStew macOS 0 12-01-2012 10:29 AM
EA Groove Quantize Assertion Error guitar486 macOS 6 01-21-2012 01:16 PM
Grid/Groove quantize: assertion failure kimmie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-09-2006 08:32 PM
How do I UNDO quantize or groove quantize in PT6.9 Asymmetric 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-24-2005 07:04 PM
Groove Quantize The Mink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-05-2004 01:01 AM
