wrong sample rate
Anyone know a quick fix for a session that plays audio files back too slow? I know for a fact that I recorded the audio at 24 48000, but the session properties were set to 16 44100. I saved a copy of the session with the right session properties, hoping that it would play them at the right sample rate, but it didn't work.
In the original session, as long as I have the clock set to adat, the session plays at the right speed, but won't bounce down at the right speed. When I set the clock to internal, it plays back slow, like when it bounces to disk. In the copied session, no matter what I set the clock to, the audio is played back slower than it should be. Any workarounds? <--- Me (idiot) JBT |
Re: wrong sample rate
In the Pro Tools Workspace window (Windows>Show Workspace) locate the audio files used in the session then, in the Sample Rate column, change the sample rate to 48000. Close the session, create a new one at the correct, 48k, sample rate and from the File menu choose 'Import Session Data' and point it to the defective session. Import all the tracks and deselect the option to convert sample rate.
If you have a bunch of files to change.. use my free Header Investigator utility.
Rail
JBT |
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
mp3 export- wrong sample rate? | Breck | Pro Tools TDM Systems (Mac) | 3 | 05-28-2009 12:52 PM |
help..session at wrong sample rate!!!!!!! | ejsongs | Pro Tools TDM Systems (Mac) | 1 | 04-21-2006 05:21 AM |
recorded at wrong sample rate!! | MaKoRancid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-12-2003 11:01 AM |
Wrong sample rate in OMF | Pietari Koskinen | Post - Surround - Video | 2 | 09-15-2002 10:28 AM |
Recorded at Wrong Sample Rate...How to Fix? | tomhartman | Pro Tools TDM Systems (Mac) | 5 | 04-12-2002 04:39 AM |
