PT9 Eleven Rack & Delta 1010lt
Hello geniuses,
Question... I have PT9. I have just started getting into it and I want to be able to use my Eleven Rack along with my Delta 1010lt sound card. Do I need to run the Eleven Rack into the S/PDIF input of the 1010lt? Can I run them both at the same time? Can I run multiple 1010lt cards at the same time? I'd like to be able to do all the Eleven Rack things I have in the past, using the pro-tools control window, ect... Help... |
Re: PT9 Eleven Rack & Delta 1010lt
I have almost the same set-up...I use the DELTA 1010 rack version. Way cleaner and easier to use IMO.
Here's my 2 cents: Do I need to run the Eleven Rack into the S/PDIF input of the 1010lt? You can if you if you want though you don't need to. I just plug a 1/4" jack out of the 11R right into my Delta 1010. I can record anything even a dry track (assuming that's what you were looking to do). Still, if you want to run S/PDIF, be sure to swap the I/O connectors (out to in, in to out) and make sure the I/O's are set properly in PT9. You should be fine. Can I run them both at the same time? No, only 1 interface at a time. Cool thing is about PT9 you can easily switch interfaces. Go to "SETUP, then "PLAYBACK ENGINE", select your hardware, click ok and then yes to re-open your session - really easy and very convenient. I use to have to use both MP8 & LE8, which sucked trying to go from all my synths back to my 11R. Can I run multiple 1010lt cards at the same time? Kinda ties to your last question. As mentioned, you can only run 1 interface at a time so no. Hope this helps. Take it ease...
SELF BUILT PC: WINDOWS 10 (64-BIT), INTEL I7-7700K CPU @ 4.20GHZ, 32 GB RAM INTERFACE: RME FIREFACE UFX+, ELEVEN RACK PRO TOOLS: PT2019.10 |
Looking to move to PC so I can use a Delta 1010LT | jj5000 | Pro Tools M-Powered (Win) | 2 | 12-09-2009 06:42 AM |
PT and Delta 1010LT | ziggy1621 | Pro Tools M-Powered (Win) | 0 | 01-03-2008 06:26 PM |
Delta 1010LT and 10.4.6 | jbmelby | Pro Tools M-Powered (Mac) | 0 | 04-23-2006 09:33 AM |
Delta 1010LT Hardware Help | NoGreatMan | Pro Tools M-Powered (Win) | 2 | 12-01-2005 03:07 PM |
Delta 1010LT cable | estregan | Pro Tools M-Powered (Win) | 2 | 05-18-2005 09:40 AM |
