Record with pre-roll
If I set up a 2 bar pre-roll and hit record on my keyboard (3 on numpad), PT plays through the pre-roll and starts recording at selection start. This doesn't work on the D-Command. PT ignores the pre-roll, and starts recording at selection start right away.
What's up with this? I must be doing something incredibly stupid?
Re: Record with pre-roll
Works as it should here. Same behavior with both.
OK, then it's one of those psycho preference thingys. I'll trash those to see if that fixes it. Thanks, Drew.
Yup, trashing the prefs did the trick.
This happened to me yesterday. I trashed my prefs, and then I could record with pre-roll from the ICON again. Today, same story. Suddenly PT ignores pre-roll again, and I have to initiate recording from my keyboard to get it back.
This is truly annoying.
I've found a workaround (besides using the keyboard and/or trashing PT prefs) that seems to work:
I've started a support case about this, and sent AVID a .ptf session file. They couldn't repro this in-house. It seems that I'm the only one seeing this issue.
Now I see that this also happens with playback too.
PITA.
Pre-roll Record | Jeffrey Talbot | Pro Tools TDM Systems (Mac) | 2 | 11-04-2010 11:36 AM |
Loop Record/pre roll | Mac88s | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-25-2009 10:25 AM |
Pre-Roll on loop record / need Preroll on each tak | CisumBlue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-23-2005 04:25 AM |
Pre-roll on record question | porkipine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 12-29-2004 01:58 PM |
Pre-roll record won't work... | Naagzh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-07-2004 10:08 AM |
