Old 01-28-2018, 02:54 AM
noiseboyuk noiseboyuk is online now
Default Deleting multiple instances of multichannel instrument presets causes crash in 2018.1
Just checking if this is universal, I've confirmed this behaviour on both Win 10 and OSX High Sierra here on 2018.1 using Kontakt 5, Omnisphere and Superior Drummer 3 (the only 3 I tried), so looks to me like it's neither plugin nor OS dependent.
1. Create a multichannel instrument preset (with at least one aux attached whose input is set to the Instrument)
2. Insert 2 or more of the same preset into a project (blank works the same).
3. Delete them both = crash.
It's also possible to crash PT when deleting individual instances of the multichannel track preset. I tested 10 instances - the 6th, 9th, and 10th all deleted ok, but the 1st, 4th and 5th caused crashes. I sorta ran out of patience at that point to prove a rule...
I once got the following error on PT relaunching, which maybe provides a clue - Assertion in "E:\ Code\ 222370\ ProTools\ NewFileLibs\ Sys\ Win32\ Sys_FileLocWin32.cpp", line 548.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 01-28-2018, 06:45 AM
TrackerLe TrackerLe is offline
Default Re: Deleting multiple instances of multichannel instrument presets causes crash in 20
No i cannot repoduce it... Deleting Aux with Plugin Inputs (Structure in my case) works fine...but Kontakt 5 behaves strange. If i change the Output Config (adding more Stereo Outputs) does not change the imput possibilities of the Aux Track...
So i cannot use Kontakt 5 in multichannel mode at all...
Old 01-28-2018, 06:47 AM
john1192 john1192 is offline
hi, do you have a network connection present and running ??? try pulling ethernet cable or turning off Wi-Fi ..
also: in #2 above you say Project .. do you meaan Session or are you trying to do this in a Project ??
just trying to refine your Steps to reproduce for others ..
cheers john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-28-2018, 11:27 AM
Sorry, my bad - yes I do mean session (local). Will try the network thing tomorrow.
Guy Rowland
Old 01-29-2018, 06:43 AM
No changes here when the network is unplugged, still causes a crash.
Guy Rowland
Can you have multiple instances of a virtual instrument (DB33)? Avi Bortnick Pro Tools M-Powered (Mac) 6 02-24-2010 03:51 PM
I/O Presets for Multichannel Outputs Dawarrior Pro Tools TDM Systems (Mac) 1 07-21-2006 05:41 PM
Instrument Tracks & instances of instruments EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-04-2006 02:34 PM
routing to multiple instrument instances, eg Mach5 ajs Pro Tools TDM Systems (Mac) 0 08-25-2004 10:38 AM
