Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 06-24-2021, 09:49 PM
Goombot Goombot is offline
Default MTRX Studio with HDX2 and Mac Pro 2019
I'm unsure if I have the cards in the correct slots. Right now I have them in slot 7 and slot 6. I'm only seeing 64 channels of HDX in my Audio/ Midi setup. Am I supposed to be seeing 128 channels or am I limited to only 64 channels because of the MTRX Studio? Or are the cards in the incorrect slots?
Old 06-24-2021, 09:53 PM
Default Re: MTRX Studio with HDX2 and Mac Pro 2019
Also, when I launched ProTools it only updated firmware on 1 of 1 cards. So I'm not sure if it's just not seeing the second card or the card didn't need a firmware update. Both cards show up in the PCI menu of my Mac.
Old 06-25-2021, 12:12 AM
Two reasons: the AvidAudioServer which allows you to use HDX hardware with CoreAudio applications has a 64 channel limit; and, the MTRX Studio has two DigiLink connectors, each of which is capable of 32 channels.
Add another MTRX Studio connected to your second card and use Pro Tools, and you can access all 128.
https://lukehoward.com/
Old 06-25-2021, 12:13 AM
Likely didn’t need an update although you can always run DigiTest. Open the System Usage window and check both cards are visible. Don’t forget they need to be connected internally via the short TDM/SATA cable included in the box.
Old 06-25-2021, 01:06 AM
BScout BScout is offline
1 MTRX Studio is only 64 channels in Pro Tools. There are more channels routable inside DADman but only 64 channels accessible to Pro Tools. Just remember every HDX card can only do 64 channels and each digilink connector = 32 channels maximum. MTRX Studio has 2 digilink connectors = 64 channels.
A full MTRX can do a lot more but that's because additional digilink cards can be added -- each one making 64 channels more available to hook to another HDX card.
Also, Audio/MIDI Setup (CoreAudio) will only ever max out to 64 channels with HDX hardware because it only works with the first HDX card.
Only in Pro Tools can you access the I/O connected to additional HDX cards.
Old 06-25-2021, 08:04 AM
Of course. Now that I’m diving into manual I see that. Thanks
MTRX Studio with HD I/O nedd Pro Tools | MTRX & MTRX Studio 37 07-04-2023 04:58 PM
Difference between MTRX and MTRX Studio? snowplaysmusic Pro Tools | MTRX & MTRX Studio 4 11-26-2022 08:48 AM
MTRX Studio tuning v MTRX SQP card Goombot Avid Pro Mixing General Discussion 9 07-15-2021 11:00 AM
Help - PTU can't see MTRX Studio via HDN TB3 Hud Pro Tools | MTRX & MTRX Studio 6 06-21-2021 12:32 PM
MTRX Studio - No AES?! Ryan Young Pro Tools | MTRX & MTRX Studio 23 02-23-2020 02:13 PM
