Feature Request: Retrospective Record
I'm not sure how to make a feature request, but I know Avid reads these boards, so thought this was worth a shot.
Now that PT 11 has much better VI performance, it is starting to become a great tool for composers during the composing process. However, compared to Logic, DP, and Cubase, there are still a number of features that would help Pro Tools catch up in workflow. One of those is retrospective record - play along to the track without being in record and at the end, hit a button and it will capture the MIDI data you just played and put it on the track. This is REALLY helpful when composing. I hope you add this to PT Avid! Thanks! |
Re: Feature Request: Retrospective Record
Big +1!!!!!!
really miss this feature. I'm really hoping now that the stuff under the hood is sorted more or less that pro tools can take some big leaps for composing workflow in an upcoming version. The bones are soooo good in PT. Which I feel is where the other apps fall short...just needs some attention to the details now. |
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Use Quick Punch recording mode.
Whenever the transport is rolling, Pro Tools is secretly recording in the background, on any record armed tracks (you just can't see it). You just have to hit / click record (either on your numeric keypad, alpha keyboard F-key, control surface, or PT GUI) before you stop the transport, or you'll loose the recording. You'll need to trim the small region / clip that is created from that point, back out to the beginning of where you started playing, but it will be there. Never tried it with MIDI, but it works a charm with Audio tracks. |
Feature Request: Retrospective record from stop. | mattrixx | Pro Tools 10 | 2 | 07-23-2012 06:13 PM |
Feature Request:32bit File Record/Export | Numi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-09-2009 01:59 AM |
Pro Tools 8 MIDI feature : "Retrospective Record" and arpeggios ? | original | General Discussion | 2 | 10-07-2008 12:57 PM |
Feature Request: record-enabled buffer size for VIs | StudioRhythm | Pro Tools TDM Systems (Mac) | 0 | 05-24-2008 08:37 PM |
Feature Request-Record Enable next track from kybd | Mt.Everest | Pro Tools TDM Systems (Mac) | 9 | 07-08-2004 10:17 AM |
