Meters are lit, but no output...
I'm using a PT 5.1.3 mix cubed system with a quicksilver G4. After closing a session and opening a new one, no audio is being spit out of the 888 24. (However, the meters show that there is output) Quitting ProTools didn't solve the problem, although the first time it occured, relaunching the playback engine, got the audio to spit out. Now, I am unable to jump between sessions without first trashing the DAE, Digi, PT prefs and restarting. Anyone have any ideas?
Thanks, -Ari- |
Re: Meters are lit, but no output...
I had the same thing happen to me recently. I trashed the prefs and resarted the computer. It didn't help. So then I trashed the prefs again and shut down the computer as well as my 888/24. That did the trick. I haven't had the problem since.
PTLUVA |
check input settings. if you have set your sync set to digital you need a clock source. try internal or just switch to analog input
hope that helps |
No headphone jack output - Meters showing output | Hotcrazyfruit | Eleven Rack | 6 | 05-06-2012 12:09 PM |
8.1 output meters | Touchwood Studios | ICON & C|24 | 1 | 09-08-2010 10:47 AM |
D-Command output Meters DEAD? | subwoof | Pro Tools TDM Systems (Mac) | 1 | 01-26-2010 02:19 PM |
Meters Follow Output Select Request | Scott Fahy | VENUE Live Sound Systems | 2 | 12-31-2007 08:57 AM |
Stereo Inputs & Output Meters on Dcommand | jlonigro | ICON & C|24 | 1 | 07-31-2006 04:39 PM |
