Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 02-28-2023, 08:31 AM
MattheWood MattheWood is offline
Default Carbon Preamps remoted to hardware trim
I see that the Carbon preamps are accessible in Pro Tools and also via Eucon control. Is there also a way to map the level trims to a hardware trim pot? I was able do something similar with the old Digidesign PRE through MIDI, but are the preamp fader values of the Carbon accessible anywhere outside Eucon?
Thank you !
Matthew
MacBook Pro 2020, 2.3 GHz Quad-Core i7, 32 GB Memory, macOS Catalina 10.15.17, Pro Tools 2021.7.0, Carbon Interface
Old 03-28-2023, 01:04 PM
Default Re: Carbon Preamps remoted to hardware trim
Bumping this one. Is there some mappable way to access this fader? Ideal situ would be something like the knobs on a Stream deck controlling preamp input level. Any way to access that controller data?
Mouse clicking on screen faders is usable, but mapping the fader would be much better…
Thanks!
Can I use Carbon ADAT OUT with 8 Preamps Simultaneously langa101 Pro Tools | Carbon 4 01-22-2023 02:17 PM
Carbon with 500 rack- bypassing the preamps / connectivity darkwavo Pro Tools | Carbon 19 06-12-2022 08:09 AM
Carbon Preamps for Classical martthie_08 Pro Tools | Carbon 5 12-23-2021 05:17 AM
Carbon Quality Preamps diogomusique Pro Tools | Carbon 12 09-24-2021 05:57 PM
carbon hardware setting in PT 2crows Pro Tools | Carbon 16 01-11-2021 03:20 PM
