Is this possible?
to sync up my 002 and hd24 together to have 40 i/o for recording and play back at the same time
Re: Is this possible?
with 2 computers....probably. But keep in mind that the HD24 is not ptle compatible, so you have to record in a different application. After recording is done you could mix in protools provided you have no more then 32 channels to mix together (limit of ptle)
What's that? - That's the machine that goes "pling". Bastiaan |
002 can only run 18 I/O at a time anyway.
mcknight44,
Sure..You'll need to accommodate the combined outputs though..24+8= 32 for monitoring /mixing. 24 is the HD24's full analog output capacity with the DA card installed, and 8 is the max # of analog outs you can get from your 002. Also ..there is a need for an external hardware sync box, that can either slave to MTC or a printed LTC track from the 002, while able to output ADAT sync via the 9 pin port. There are a couple of choices out there..Google it. happy tooling,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
