Old 11-07-2010, 01:06 AM
RoverRadio RoverRadio is offline
Default Nothing but static
Using PT 9 on Windows 7-64. Have tried a couple of audio cards (Asus Xonar DS and M-Audio Firewire Solo).
Have the same issue on each: I get nothing but static on playback.
I can import or record into the session and see the waveform properly. But playing it back results in white noise static. The level meters also peg at the top - they don't reflect the ups and downs of the waveform.
I intend to only use this system for mixes of video projects - no major recording, music stuff.
Any ideas?
Old 11-07-2010, 01:09 AM
M-ManLA's Avatar
M-ManLA M-ManLA is offline
Default Re: Nothing but static
Clean install of OS maybe?
www.M-ManLA.com
www.facebook.com/MManLA
www.soundcloud.com/m-manla
Pro Tools 12, Sibelius First 7/Presonus Studio 192/Windows 10 Pro
Old 11-07-2010, 10:09 AM
Oy...hope not. There's a day shot. Any other suggestions? All other apps using audio (Adobe Audition for instance) work just fine.
Old 11-08-2010, 12:21 AM
M-ManLA's Avatar
Make sure your audio drivers are fully updated, and your chipset drivers is updated. Also make sure that you change the Asus Xonar control panel settings to see which one works. I know that DSP mode on can mess with the audio.
www.M-ManLA.com
Old 11-14-2010, 06:09 PM
Unfortunately that didn't help. Have tried 2 other audio cards, native ASIO and ASIO4ALL drivers, nothing works. A complete OS re-install simply isn't possible now (in the middle of some video projects)...I guess I'll just sit on PT9 for a month or so until I have time to mess around with t.
Old 11-14-2010, 08:23 PM
Absolutely! Don't make a change in the middle of a project. Actually, you CAN, but I would simply remove the system drive and start fresh with a new one. This way, you can swap out to your present drive and get things done(that's how I work in EVERY update).
[IMG] code is Off
Static dieseldave Pro Tools Express on Windows 2 06-30-2013 09:29 AM
Static "Playback" with Protools and Static "Playback" with windows files 39lashesmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-20-2011 05:57 AM
help me ... STATIC cleavelandjones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-13-2006 06:29 PM
ok still i have static what can i do streets 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-16-2004 06:32 AM
!!!Static!!! Severe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 07-02-2002 09:29 AM
