Can you suggest a windows laptop with good LatencyMon results?
Hi everyone,
Can anyone tell me a Windows laptop that has excellent performance after testing with the LatencyMon application? information: https://www.resplendence.com/latencymon I currently have a 2020 DELL G7 7790 notebook (i7 CPU, 32Gb Ram, etc.), use Pro Tools and a UAD Universal Audio Apollo Twin X Quad Heritage Edition interface. During recording the CPU usage counter constantly shoots towards 100%. The LatencyMon test presents terrible results as shown in the photo; I consulted various tutorials and articles, implementing the suggested changes, I reinstalled various versions of Windows (Home, Professional, LTSC 1809, LTSC IOT 21H2, 22H2), trying both with Windows Update updates and from the official Dell website, but there is nothing to do, the result does not change. Instead of getting lost in a jungle of tweaks and modding, I would rather sell my Dell G7 and buy a new laptop that works well in audio. I discovered this article https://www.notebookcheck.net/DPC-La....504376.0.html which lists laptops based on LatencyMon results. If you can point me to a notebook that doesn't cause problems I would be grateful, considering that it must also have a Thunderbolt 3 (or 4) socket necessary for the Apollo. I also want to point out that in addition to the notebook I have a fixed desktop PC which is working wonderfully, it is a PC assembled with a Gigabyte z590 vision D motherboard, i7 CPU, 64Gb Ram, etc. and LatencyMon gives great results. I thought that it was enough to make the same optimizations in Windows and in the BIOS to be able to have a "mobile copy" of my desktop system on the notebook, but unfortunately this is not the case. Thanks in advance to anyone who wants to answer me. Angelo |
Re: Can you suggest a windows laptop with good LatencyMon results?
Have you done all the Avid optimizations? See the Help Us Help You link at the top of each forum.
Also, here are a few links to look at: http://duc.avid.com/showthread.php?t=377580 https://www.tenforums.com/tutorials/...a.html#option4 https://duc.avid.com/showthread.php?t=410360 Otherwise, some on the forum have had good luck with Lenovo laptops. Do a search for them.
Further, when using latencymon, I configured PT to run on cores 2-12, and Latencymon to run on cores 0-1, while monitoring cores 2-12. Not sure if it made a difference to the latencymon results or not, but it seemed reasonable to me to do so. As said here on the thread, do the optiimizations á la Avid as far as possible on your dell. On top of that i follow the optimization advice given by youtuber Mike on his channel Creative Sauce, and that made quite a difference. And a 'hunch' tells me you should try the - configure PT to run on all cores but the lowest one or two - trick Yeah - it's a mess, but finally it works good enough. /T
Free beer tomorrow !! - but until then - we're stuck in the present moment |
Out of curiosity, I installed in on an ancient (11-12 yr) underpowered HP ProBook 4730s laptop, 8 GB ram, old i7 quadcore, with Intel built in graphics. I took all Win 10 updates, maxed the power options, disabled blue tooth & wifi, no devices attaced to laptop, and then ran LatencyMon for a full hour. It said "Conclusion: Your system appears to be suitable for handling real-time audio..." and all green graphs. So, what does that tell you? If (big IF) your Dell is properly optimized & the OS is fully up-to-date, you "should" not have any LatecyMon issues. Have you checked all hardware as well? CheckDisk? Mem test? etc?
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
This is luck of the draw really. One bad driver or odd WiFi card or strange BlueTooth chipset and you can get bad results.
When I looked at this a few years ago, Razer were recommended by the folks at UA. I had good luck with a Clevo, which is an OEM product. But that was a while back. In the end I opted for Mac, as CoreAudio was always written with priority and didn't have the same problems. But there are versions of MacOS with a similar problem now...... I did go into a store and try downloading latencymon onto a few of the machines. As pointed out, the ACPI battery service is lousy on a lot of laptops. If you ignore that one (because it's a common problem, and it's possible to disable that service) you might find a machine which doesn't have any glaring problems. Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon. |
Lenovo, yes, I have heard it and experienced it myself. So I have for sound projects specially Lenovo laptop. I bought it in this regard so that it would be as powerful as possible, but I did not invest in the video card. I think it does not matter so much, unlike the gamers. Players need a powerful video card, that is certain. Improve me if any audio project requires it too!?
Good PC laptop results with PT8 | converted | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-06-2010 01:02 AM |
laptop users getting good results with m-powered? | sonicz | Pro Tools M-Powered (Win) | 2 | 06-12-2006 07:45 AM |
Good MBox results with Compaq laptop | didger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-11-2003 03:26 PM |
Suggest a PC Laptop | Kimberly Thomas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 06-06-2003 10:45 AM |
Can anyone suggest a good DVD-R... | Opal Music | General Discussion | 9 | 12-03-2002 09:16 AM |
