Old 05-14-2018, 03:58 AM
taylor4814 taylor4814 is offline
Default Dropbox Folder as Session Location?
I tried using my Dropbox folder on my system drive as the location for a session file that I used only as a template design, no recording -- make edits, then "Save as Template" into my system templates. Twice in the last week, while simply saving, mid-editing, some error message was generated, and upon viewing the Dropbox folder contents, the session file name was completely corrupted....
Are you in fact able to work on sessions located in a Dropbox folder? I've never had any issues with other kinds of files in Dropbox before...
Old 05-14-2018, 04:02 AM
amagras amagras is offline
Default Re: Dropbox Folder as Session Location?
The DB folder is usually located in the system drive and iirc the manual recommends not to work from the system drive, especially if the session has audio files. Maybe that's what happens.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 05-14-2018, 07:56 AM
BScout BScout is offline
Yes. Do it all the time.
You can move the dropbox folder to a different location/drive (which is necessary due to the size of my Pro Tools sessions collection.)
Pro Tools generates a lot of autosaves and Dropbox attempts to constantly save so while working with a session, if someone else is watching the dropbox-sync (or on another computer sharing the folder) you'll see it slowly populate with a lot of temporary pro tools sessions (just the session file/not the audio files) with gibberish names (those names are actually given by Dropbox through the sync process.) Not to worry -- once the session is closed (after your final save), all those weird files will clear out of the dropbox.
It's actually one way we can tell not to open a session since someone else is working on it.
(Dropbox, during the sync process, creates a alpha-numeric named file while it does the copy and then afterwards changes the name once the sync is complete to the actual filename. It's a safe way to do a copy just in-case the copy fails, the partially synced file doesn't overwrite the already synced file. The thing with Pro Tools is when a session is open, the file is constantly changing so there ends up a lot of partial-syncs that never finish.)
Old 05-14-2018, 10:22 AM
SomeOtherGuy SomeOtherGuy is offline
I've done this for the last 5 years. My system drive is a fast SSD internal on a trashcan Mac Pro. Working inside DB allows continuous backup (it's not my only backup), but also allows quick sharing as everything is already in the cloud. Plus you can easily revert back to prior PT session versions if you need to. I highly recommend––
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Old 05-14-2018, 11:01 AM
Cool, well that's encouraging, I'll keep at it then... all the major cloud services have always seemed very robust to me, never had any issues with document files, etc being corrupted... possibly I'm hitting Save too much, mid-edit...
What would be ideal is if Avid Cloud Projects also had a "Save as Template" option... I'll submit to IdeaScale
Old 05-14-2018, 12:47 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
How about disabling sync while you're recording, then re-enable when you're done. All of the "partial incomplete" syncs while you're working could be most of the problem.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 05-17-2018, 07:39 AM
off the wall's Avatar
off the wall off the wall is offline
The only issue I've had running sessions off a DropBox folder is that if anyone else is syncing that folder, it is a nightmare for them with the temp files and backups constantly changing.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 05-21-2018, 08:04 PM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
I've been storing my projects in a dropbox folder without issue. It's nice having an instant mirror of everything you are working on. Though, I haven't done real-time collaboration with others with this configuration.
I have noticed that Dropbox seems more efficient on MacOS than on Windows. On a Mac, you barely notice that it's running. On Windows, it seems to be a bit more CPU-hungry.
Dropbox – Mac OS X – Alias of 'Recording Files' folder ztrich Pro Tools 11 2 01-04-2017 09:01 PM
Running PT11 Sessions from Dropbox folder pgripp Pro Tools 11 8 01-29-2016 10:24 PM
unused plugin folder location orvillej RTAS & TDM Plug-ins 2 06-28-2013 09:15 PM
Session Folder Location Alexander4444 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 04-06-2010 04:13 PM
default folder location pauldub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-06-2008 09:14 AM
