Old 07-06-2008, 05:16 AM
rageagainst rageagainst is offline
Default midi - Elektrik Piano
OK! i recently bought Elektrik piano fromNative insturemnts. TRouble is im not sure how to interface with protools!
I have never used midi in proools before so please be explicit with your replies!!
So far i have created an audio track and insetred the piano plugin. I changed the chanell on the piano to 10. I can hear the piano through protools, but im unsure how i get the midi to track on my new "midi track" i created. how do you set this up?
Thanks
Old 07-08-2008, 04:32 AM
Default Re: midi - Elektrik Piano
surely someone must know?
Old 07-08-2008, 08:53 AM
Ozzie Ozzie is offline
Create an instrument track, insert Elektrik Piano plug on that track, select record on the instrument track and away you go.
This is the easiest method but I suggest reading the manual, on instrument tracks and midi tracks.
Regard
Old 07-08-2008, 01:15 PM
good idea, but i only got V6.9 :-( dont have insturemnt tracks!
Old 07-08-2008, 03:35 PM
Create an Aux track and Midi track, insert plug on the Aux track and route the output of the midi track to the Elektrik Piano.
Old 07-09-2008, 12:48 PM
I choose Electik piano as the output on the midi track but next to it (see Pic) it says "no channels selcted" so how does onego about selecteing channels?
Thanks
http://img.photobucket.com/albums/v2...gainst/123.jpg
Pro tools 9 and plugin elektrik piano no work pansement Virtual Instruments 4 04-26-2012 12:36 AM
Akoustik/Elektrik Piano Solution! WIN7 64 dorazio87 Virtual Instruments 0 08-26-2010 12:31 PM
Native Instruments Akoustik & Elektrik Piano Compatibility on Leopard & Snow Leopard DigiTechSupt Virtual Instruments 0 01-07-2010 11:08 AM
NI's AKOUSTIK and ELEKTRIK piano problems within ProTools teacherman Virtual Instruments 3 05-01-2008 07:01 AM
Lounge Lizard or Elektrik Piano? Dan Pinder Tips & Tricks 19 02-08-2006 10:17 AM
