upgrading current configuration...
so, if all of a sudden my digi 002r is not enough for me and i need more I/O, what do you guys suggest? adding another 002r? and how is this done? via firewire?
thanks in advance |
Re: upgrading current configuration...
you can't use more then one 002 on a computer. look in to the presonus digimax, it will give you an additional 8 inputs
thanks buddy, I have checked the prices, and they are a bit more than I can afford...any other similar but cheaper solution? is firepod compatible with 002r? if not, i guess i will have to start putting some money aside, because digimax lt sure does look like a killer product!
is a MOTU 828 MKII also an option?
Basically, NO Firewire interface is useful as expansion for the 002 or 002R, except via the ADAT ports. ProTools will only talk to a Digidesign interface, and only ONE at a time. Any added ports need to be connected via the ADAT optical port or the S/PDIF port.
When you say you need more I/O, do you mean just line level, or mic inputs? The two best deals for getting 8 more mic inputs are the Presonus DigimaxLT ($800) and the M-Audio Octane ($600)
Quad 2.5 G5, 4.5G RAM |
thanks for the info, I would like to have both line level and mic inputs, just like the digi 002..i'll see what i can find for up to 800 $, now at least i know what i need
UNBELIEVABLE!
check it out, I have found a way to get more inputs...it doesn't get any cheaper than this! http://www.soundonsound.com/sos/jun0...75376a431fea97 |
Path for upgrading Mbox 2 Pro with 7.4.2 LE to current | jonjenkins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-04-2012 11:16 AM |
Exceeded Current Pro Tools Configuration | Danny Simcic | macOS | 1 | 11-08-2011 12:08 PM |
The maximum number of tracks already exists for the current Pro Tools configuration | wreckthisplace | Pro Tools M-Powered (Mac) | 2 | 09-28-2011 10:53 PM |
Upgrading 6.1 to current 7.3.1 + Win Xp Sp1 to Sp2 | Jay Terrien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-27-2007 08:53 PM |
Upgrading to the current version - Questions | kitana_one | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-12-2005 06:37 PM |
