Old 06-14-2002, 10:22 AM
Irl Sanders Irl Sanders is offline
Default SSC - multiple outputs via SC2+?
Can the "outputs" of SSC be routed to the hardware outputs of a SC2+ card? I'd like to use SSC as a bigger 'RAM tank' for an existing SC2 card. Phone support said this is possible, but I'd like to see it in writing before I buy. Would this work stand-alone, without ProTools running?
Thanks,
Irl Sanders
Los Angeles, CA, USA
Irl Sanders
Music Editor
LA, CA, USA
Old 06-20-2002, 10:10 AM
Default Re: SSC - multiple outputs via SC2+?
bump
Irl Sanders
Music Editor
LA, CA, USA
Old 06-20-2002, 10:48 AM
Mark Ziebarth Mark Ziebarth is offline
Hi Irl,
I am not 100 percent sure but I think that does not work. I have both SCII card and SSC on a Macintosh TDM system. If I start to load a sound the software asks me whether I want to use it on SC II card or SSC. In a tdm-setup there is no link between both.
But I think you use it without TDM as you want to have more outputs for SSC. In tdm it has 32 outputs to the tdm bus, that's a lot...
I don't think you can use a SC II card as a Direct I/O device.
But as I mentioned before, no guarantee on this...
Regards
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 06-21-2002, 09:00 AM
Thanks Mark - that's as I suspected, but two different pre-sales guys at Digi told me otherwise. Moral of the story...never trust a saleman!
Irl Sanders
Music Editor
LA, CA, USA
Old 06-21-2002, 02:31 PM
jeffro's Avatar
jeffro jeffro is offline
Mark is correct.
Samples loaded in Soft SampleCell cannot be played out through a SampleCell card.
Soft SampleCell can use Sound Manager (2 outputs via Mac), Direct I/O (up to 16 outputs via digi hardware), or DirectConnect (32 outputs via PT software).
linkedin
Old 06-24-2002, 08:47 AM
VIA DIGI HARDWARE is the confusing phrase in the sale literature, as an SC2 card is indeeed Digi Hardware, is it not? Perhaps a Pro Tools audio interface should be specified. Also, someone should straighten out the guys in pre-sales, as they blew this question TWICE.
Irl Sanders
Music Editor
LA, CA, USA
Old 06-26-2002, 09:00 PM
Nick Batzdorf Nick Batzdorf is offline
Maybe they meant that you can load *SampleCell* (no Soft) samples onto the card and use its eight outputs.
Old 06-26-2002, 09:02 PM
Oh, and there's a TDM daughtercard for the SampleCell card that routes its outputs into the TDM mixer. No DirectConnect needed - the cards are connected with a ribbon cable.
Old 07-05-2002, 11:41 PM
jeffro's Avatar
With a SampleCell II PCI or Plus card installed, the Soft SampleCell Editor gives you the choice of loading samples into the Mac's RAM or the SCII's RAM. Maybe that's what they were referring to.
I'll send a note to the sales crew when we are back in the office on Monday to clarify this.
linkedin
HTML code is On
mix to multiple outputs scottpetito Pro Tools TDM Systems (Mac) 0 05-13-2008 04:37 AM
Multiple outputs beelzebub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-29-2007 10:00 AM
Multiple Outputs? Digitalkidd Virtual Instruments 9 02-19-2006 05:36 PM
Multiple outputs for multiple players. KingFish ICON & C|24 1 05-08-2004 01:13 PM
Multiple outputs MaizeBass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-22-2002 07:58 PM
