  #51
Old 02-28-2023, 01:44 PM
EddieJones's Avatar
Default Re: EUCON 2022.12 Released
So this looks like Wifi and the network is 192.168.1.x (1-254) Is this your internet router?
Do you have any other router or network adapters?
  #52
Old 02-28-2023, 01:50 PM
mlavin00 mlavin00 is offline
Correct. 192.168.1.46. DNS 255.255.255.0
I have 2 routers. I changed the cable to my main router so the number changed.
The S1 is showing: 192.168.100.46
  #53
Old 02-28-2023, 01:52 PM
EddieJones's Avatar
OK, great.....so that second router is 192.168.100.x is connected to the S1....it also needs to be connected to the Mac through an ethernet port. Can you check to see if thats the case.
  #54
Old 02-28-2023, 01:55 PM
Correct. The S1 via cable to the router. The router cable to the Mac. Still not showing up in the Surfaces L side panel however.
  #55
Old 02-28-2023, 01:56 PM
EddieJones's Avatar
Can you post a pic of that adapters settings from the mac like the wifi one
  #56
Old 02-28-2023, 02:02 PM
File Type: jpg Screenshot 2023-02-28 at 4.00.28 PM.jpg (26.7 KB, 0 views)
  #57
Old 02-28-2023, 02:03 PM
Should the S1 actually be 192.168.100.300?
  #58
Old 02-28-2023, 02:06 PM
EddieJones's Avatar
This is not the other router...this is the same as the Wifi Router. You need to plug this into the router the S1 is plugged into not the Internet one.
  #59
Old 02-28-2023, 02:07 PM
EddieJones's Avatar
Thats not a valid address. The S1 will get its address automatically (just like the Macs wifi and ethernet adapters)
  #60
Old 02-28-2023, 02:17 PM
The S1 is plugged into the same router as the Mac. I have it set at 192.168.1.46. Subnet is 255.255.255.0.
The Router 192.168.1.1. Should this be the setting?
EUCON 2022.9 Released EddieJones Avid S1, S3, Dock and Control App 18 02-28-2023 08:12 AM
EUCON 2022.12.1 Released EddieJones Avid S4/S6 42 02-06-2023 05:39 PM
EUCON 2022.9 Released EddieJones Avid S4/S6 4 09-27-2022 08:09 AM
EUCON 2022.4 Released EddieJones Avid S1, S3, Dock and Control App 17 05-08-2022 07:26 PM
EUCON 2022.4 Released EddieJones Avid S4/S6 0 04-29-2022 03:32 PM
