Old 02-03-2010, 10:50 PM
ostrange ostrange is offline
Default Pro Tools 8 shuts down during session playback AHHHH!
I loaded up a session for further mixing and while im playin it back pro tools 8 shuts down instantly with no warning!! is this considered a corrupt session now??? i even opened it back up and took off my t-racks on the master and it shut down again before playback and all my 003 faders were still up as i was brought back to the desktop.Anyway i can fix this???? delete preferences,update to 8.0.3,save as to new location,copy the session folder to new location??? I need help! my client is comin 2morrow and he has no idea.
Old 02-03-2010, 11:35 PM
Default Re: Pro Tools 8 shuts down during session playback AHHHH!
post a sandra report. details at the top of this forum.
need exact details of what version of pro tools, 8.0 cs1- 8.03 whatever it is
plugs in the session, track count etc.
if you can open it and do a save copy in w/o it shutting down, do it and save it to another drive other than what you are copying to.
did you delete your prefs, databases and such???? if not get the digitech support utility or search for my app on here, trasher, and run it. then restart.
try right clicking on your pt session icon and rename it. sounds goofy but has worked.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 02-04-2010, 12:18 AM
So i renamed the folder and session file,opened the session and it went halfway thru the song and it got a hardware buffer error for some reason then crashed!! i tried "save copy in" and it crashes as soon as i pressed okay.ill try delete pref,data method,your app and the 8.0.3 update to see if it works! ill report back when im done
Old 02-04-2010, 02:24 AM
So i did all the above and still crashed! then i opened the session again and put empty space all the way up to the start,made a new session,imported session data and crashed on first track called "intro/outro" so i had a feelin it was that track messin everything up.I opened the renamed session and erased that track along with file in the session pool and it worked fine! i guessit was the way i named it.Ive worked with that session a handfull of times! so why would it give me probs?? anyways seems to be workin now
Old 02-04-2010, 03:08 AM
caruso7r caruso7r is offline
Did you by any chance import any stereo interleave tracks by mistake? I did this and they came into the session as mono and played for a moment and sure enough the session would crash without warning. Just a thought.
John
Pro Tools 12.5
Macbook Pro & Windows 7 Ultimate 64 Bit
Old 02-04-2010, 03:18 AM
I should of been more clear on this. I imported from nuendo a omf file and it included stereo interleave tracks of organ parts so when i started to get a mix going, as soon as the organ started playing, the session would freeze up and quit on me. No errors, nothing. So I finally realized that the organ came in as mono when it was clearly stereo from the nuendo session so i had to import just the audio files and convert to multiple mono and of course everything went fine after that.
John
Pro Tools 12.5
Computer Shuts Down mid-session! tdawgg Pro Tools M-Powered (Win) 11 04-11-2009 01:36 PM
Closing Session Shuts Down Pro Tools ryanwilsonfive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 10-18-2007 11:00 AM
Protools session shuts down on open Daxdoug 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-18-2005 04:01 PM
Protools Shuts down when i open a session hanij 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-15-2005 01:00 PM
long "save" during playback, shuts down plug in automation Jules Pro Tools TDM Systems (Mac) 5 08-17-2000 04:15 PM
