Old 12-12-2004, 01:27 AM
Aural Exciter Aural Exciter is offline
Default plugin phase issues
Hi there,
just noticed something really annoying using the TRacks EQ. 2 Snare Tracks ( top + bottom ), as perfectly in phase as they can be. instantiated the TRacks on the top track, manually time adjusted the 2 tracks, and ... well, the snare was destroyed, totally unusable. I didn´t even had the TRacks really doing anything, flat EQ Curve. I just activated it and it totally messed up the phase.
then duplicated the top snare, phase reversed it, mixed it with the TRacks track ( still flat )just to see what happens and it was even worse, no cancellation to speak of, actually both tracks in phase cancelled out a lot more.
Am I missing something here or is it really that bad with the TRacks ?? ( never had anything remotely like that using any other plugs )
Has anyone of you experienced similar things with other plugins ?
cheers,
Markus
Old 12-12-2004, 01:54 AM
KingFish KingFish is offline
Default Re: plugin phase issues
Try returning the tracks to the way you recorded them, and using the "short" Delay compensation Engine in the Playback engine if you're using PT 6.4+
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 12-12-2004, 09:50 AM
5down1up 5down1up is offline
dont know the plug your talking about .
but if i have f.ex 2 tracks of guitars and wanna f.ex flip the phase on one track to hear what´ll happen and insert the plug ( rtas , delay amount shows zero ) on just one track it starts sounding different . so at least i make sure having the same plugs on both tracks to hear whats really going on .
wired yeah
Phase issues Toontrack macOS 3 02-14-2012 06:59 AM
Phase issues BothMan Post - Surround - Video 4 01-25-2004 09:35 PM
What are phase issues? MaKoRancid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-16-2003 04:51 PM
Plugin for Phase correction? LarryLatham Pro Tools TDM Systems (Mac) 15 02-04-2003 05:04 PM
Plugin for phase alignemnet maxserg Pro Tools TDM Systems (Mac) 0 12-05-2001 09:00 PM
