Old 12-31-2005, 08:50 AM
Media Man Media Man is offline
Default Best Control Surface under $1500
Don't have the budget or space for a Control 24. I'll get something better when I have more room.
In the meantime..
I'm looking at Tascam US2400 (24 faders), and several 8 fader control surfaces, such as Digi Command 8, Mackie Universal Control, and Tascam FW 1802 and Tascam 1884.
Any experience with these?
Any Pros and Cons comments would be appreciated.
Mark
Old 12-31-2005, 04:28 PM
Vaphoron Vaphoron is offline
Default Re: Best Control Surface under $1500
I love my Command 8 and I wouldn't go with anything else currently out in the same price range. I believe the C8 will access a lot more functionality in PT than the third party "HUI type" control surfaces but I don't know for sure because I haven't actually used them.
- Jason
Old 12-31-2005, 07:41 PM
DaveSB DaveSB is offline
Mackie Universal Control is a good buy around $900 new street price
Old 12-31-2005, 10:35 PM
blumediaprojekt blumediaprojekt is offline
does the command8 have the ability to load eq's reverb's and dynamic's plugs that you've set as your standard plugs? If that makes any sense?
like, you could set sony oxford eq to be the standard eq that you will want to use usually for an eq......
just thinking outloud
blah blah blah,
adam
Old 01-01-2006, 08:46 AM
mixer mixer is offline
the original hui with 1.45 system has a lot more functionality that the universal control actualy even more than control 8 more dedicated buttons and works great with pt7. you can probably find one cheap.
www.garyvandy.com
Old 01-01-2006, 10:16 AM
bigbadhenchman bigbadhenchman is offline
As an additional controller to any fader pack, you can also look into adding the Belkin N52 Nostromo. I just picked one up, and it's very cool.
It's completely programmable, and can be used to program key commands with a single click.
M-Powered Forum
www.markhensley.tv
Old 01-02-2006, 03:43 AM
blah blah blah,
adam
You can't actually insert a plug-in with the C8, only select a plug-in already inserted and control it.
- Jason
Old 01-02-2006, 10:32 AM
ripple FX ripple FX is offline
Hey Mixer - any idea where to get the 1.45 software for HUI? I didn't find anything at mackie.com. Mine's ver 1.3.....
http://www.ripplefx.com
Mac Pro 8 core 3.0GHz Harpertown
Magma PE6R4I - HD 3 Accel +1 Process
Control 24 - 96io - 1622
OSX 10.6.8 - PTHD 10.3.10
Old 01-02-2006, 10:34 AM
i called mackie and got it direct from them..its chip and you install it yourself..large improvement.
www.garyvandy.com
Old 01-02-2006, 10:41 AM
I'm all over it. Thanks!!
003 control surface (As audio) & control 24 as surface crizdee ProControl, Control|24, Command|8 7 01-04-2016 12:30 PM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
XD CAM (PDW-1500) Machine Control? Neps Post - Surround - Video 0 02-04-2009 12:24 AM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
Machine control profile for DSR-1500? espron Post - Surround - Video 0 04-14-2005 12:01 PM
