Old 10-06-2013, 07:52 PM
[email protected] mccoyrare@yahoo.com is offline
Default Latency issues
If you have latency issues, should you increase or decrease buffer size?
Old 10-06-2013, 08:01 PM
Marcel Risberg's Avatar
Marcel Risberg Marcel Risberg is offline
Default Re: Latency issues
You should decrease the buffer.
A decreased buffer will make your sound go through your machine faster but at the same time it will also make your hardware need to work harder.
What's your interface and what are your buffers set to now? Also, what are your computer specifications?
Marcel Risberg
Production sound and audio post - ljuddesign.se
Enthusiastically sharing knowledge and experience at Stockholm Film School.
🛠 Pro Tools Ultimate 2019.10 · HD Native · HD Omni
🎚 EuControl x.x.x · Artist Control · Mix · Control App
🦑 MacPro5,1 · 12C24T @3.46GHz · 48GB · SSDs · macOS 10.13.6 (17G5019)
📺 Separate video playback machine
🥇 Covered by ZDT/TLC · Keeping DAW OS clutter free
Old 10-06-2013, 08:18 PM
I'm using Mbox 3, and its buffer size is set to 256. I have an i7 Quad core laptop w/ 8 gig ram 1 TB, 2.2 ghz with turbo boost up to 3.9 ghz, with 6mb cache
Old 10-06-2013, 09:11 PM
Did you try setting the buffer to 128 or even 64?
Your machine seemed quite fast judging by the specs. What OS? Is it a Mac?
Marcel Risberg
Old 10-09-2013, 07:56 PM
Its a pc. A higher end laptop. What actually cause latency issues?
Old 10-10-2013, 09:34 PM
The way I see it; computer processing power (CPU), or the lack of it, mainly causes latency issues - up to a certain point that is. The audio interface and its drivers as well as physical connection (eg Firewire / USB / PCIe) also affect latency as well as stability when the system or session gets heavily loaded.
Look at it this way: The system as a whole affect latency. Choose your components wisely and don't forget to be creative about it.
For example: A bigger session might require you to increase the buffer size / latency to be able to run on your machine. A smaller sized session might allow you to decrease the buffer which shortens the latency. Some times when I need to record something which requires a minimal buffer size but my session is to big for my machine to handle at a smaller buffer - I bounce my session with hundred tracks down to a two track session, record at ultra low buffer settings, and then import what I just recorded back to the larger session .. and voila.
This is a fairly decent article with pictures describing what latency is about:
http://www.presonus.com/community/le...-audio-latency
Marcel Risberg
Old 10-11-2013, 09:12 PM
Thank you
Old 10-11-2013, 10:47 PM
Thank you
You're welcome. Have a nice weekend!
Marcel Risberg
Latency Issues dmils 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-24-2010 08:09 PM
Latency Issues - changing latency has no effect Kippa-Dee Pro Tools M-Powered (Win) 1 07-15-2010 08:39 PM
Latency Issues, Please Help!!! daveseviltwin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-19-2010 07:01 PM
latency issues stainless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-23-2009 08:27 PM
LATENCY ISSUES WITH 7.3.1 KRAFT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-30-2007 09:23 AM
