Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 06-27-2013, 12:43 AM
Becharax's Avatar
Becharax Becharax is offline
Default iMac 2011 and Later and SSDs
Hello Guys,
Just a question, does anyone know if replacing the HDD with a third party SSD ""OR"" adding a third party SSD to the already installed HDD into an iMac 2011 would cause the fan to run at full spped and be noisy ??
I got an intel 520 SSD that I am reluctant to install ...
Any Advice ?
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
Old 06-27-2013, 01:59 AM
CME CME is offline
Default Re: iMac 2011 and Later and SSDs
Swapping out the original HDD can cause that. But owc has a cable kit that comes with a special cable the fixes that problem if you want to swap the original HDD. Adding an SSD and keeping the original HDD shouldn't cause the problem.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 06-27-2013, 02:16 AM
Becharax's Avatar
Can you link me please??
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 06-27-2013, 02:40 AM
Becharax's Avatar
Oh you mean if I add an additional SSD to the original HDD there won't be any fan issue ??
If that is so ... how can I do it ?? any tutorial ?
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 06-27-2013, 06:38 AM
CME CME is offline
http://eshop.macsales.com/item/OWC/DIYIM27SSD11/
And they will do it for you. And have an esata option. It's under the turnkey options at the bottom of the description
http://eshop.macsales.com/item/OWC/DIYIM27HDD11/
And this is the kit for swapping the HDD. And if you're doing both, you can buy one full kit with tools and one kit with just the cables.
Old 06-27-2013, 08:14 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
There are great tutorials on ifixit.com for taking apart an imac. You'll need a pair of good suction cups and a torx screwdriver(can't remember the exact size, but it's listed on ifixit's tutorials). If you're used to working on laptops it's not that hard, but it's a little nervewracking when you pull the glass off the first time.
There are 3 places you can put an SSD in a 2010-2011 imac:
1. Internal hard drive (3.5") location - if you put it here and remove the 3.5, you will get fan ramp up
2. Internal SSD (2.5") location - If the imac didn't come with an SSD, the bracket is missing, so you need to use double sided tape or velcro to mount the SSD, but the SATA connection is there.
3. Optical Bay - There are adaptor cases for putting an SSD in place of the optical drive that run about $50... You can get them from ifixit.com. The optical drive has a thermal sensor taped on to it, just gently peel it off and stick it to the new adaptor case.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Benchmarking Pro Tools 11 and iMac Mid 2011 Becharax Pro Tools 11 0 08-09-2013 04:31 AM
Pro Tools 11 with Imac 2011? comp85 macOS 4 07-23-2013 01:56 AM
iMac 2011 - i5 intel CPU YYR123 macOS 7 12-24-2012 04:40 AM
iMac 2011 apples 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-24-2012 06:56 PM
iMac 2011 & Mbox2Pro groovesong macOS 1 09-23-2011 09:21 AM
