Old 07-01-2021, 07:06 AM
lrmusic70 lrmusic70 is offline
Default Carbon & Phantom Power recall
Hello all,
Just got my Carbon. All my I/O settings are recalled correctly each time I power up with the exception of any inputs that require 48v. This requires me to go through the inputs on the front face of Carbon and turn on phantom power for each mic that needs it. Not a huge deal, but seems to be an annoying lack of recall before I can get creative. I have not found a solution on the software side.
Any one else had a similar issue, found a solution?
Thanks,
JN
Old 07-01-2021, 07:25 AM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Default Re: Carbon & Phantom Power recall
Originally Posted by lrmusic70 View Post
Hello all,
Thanks,
JN
Hello,
This is by design as a safety precaution to protect against the case where a user may connect a ribbon mic when the unit is powered off. Then, power on the unit and not realize phantom power is being applied. Depending on the particular ribbon mic, this may or may not be an issue. But, we wanted to err on the side of caution. That said, the opinion on correct behavior here differs. I'd heard users say they like that phantom power is disabled on power up. And, others say they don't. So, we may need to create a preference for "Disable 48V when device powers on" in the future to accommodate both types of users.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 07-01-2021, 10:10 AM
Kyle,
Thanks for your prompt response. From a design perspective, erring on the side of caution certainly makes sense, especially in a high traffic commercial studio where setups and engineers can change with the wind. But with project studios like mine where the configuration is 99% static, it would be a god-send to have the ability to set-it and forget it.
To avoid the ribbon mic disaster, having the start-up default set to disable 48v would be sensible. As the end-user, the ability for me to go in to software settings and toggle it off so that it would stay active on continuous start ups would hopefully satisfy both camps/concerns- at that point, the designers did their best to warn and protect, but also gave me the ability to choose for convenience- any fault should be on me as I changed it.
I would welcome the patch change to make it happen.
Best,
Jeff
Old 07-01-2021, 10:11 AM
Kyle,
Best,
Jeff
Yup, totally reasonable request. Thanks for the input!
Kyle Splittgerber
Berkeley, CA
Old 07-02-2021, 03:44 AM
LFO LFO is offline
Yes, although it's not a big deal, a preference tab would be great !!
Old 07-07-2021, 07:23 AM
K Roche's Avatar
K Roche K Roche is online now
Not really an issue for me BUT Yes would be nice feature. Especially since my ribbons actually use phantom power to run on.
System :
Enjoy the Journey
.... Kev...
002R Faults + power harness + no phantom power DaveSB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-26-2009 01:10 AM
recording with phantom power *and* without phantom power simultaneously SweetSoulSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-22-2008 07:40 PM
phantom power? dealage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-29-2005 07:55 PM
Phantom power and mic with power supply? hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-20-2005 12:56 PM
Power Harness Recall of the Recall ! ChuckLogan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-21-2004 09:06 AM
