Ugraded to 11/10.3.8 co-install, Komplete 8 Ultimate, Hybrid gone
So I just upgraded from Pro Tools 10.2 to 11.1.2/10.3.8 co-install. Before I upgraded, I checked in the NI Service center and noticed in the "Updates" area I had all the AAX 64-bit compatibility for PT11 updates ready for download. I chose not to download them yet as I did not have PT11 yet.
When upgrading to PT11 I had to get a new computer that would be compatible (new specs updated on my sig.), so I transferred everything on my hard drive over to the new one using Migration Assistant. After a long week of installing PT11 and updating/upgrading most of my other 3rd party plugs, with the exception of Hybrid (which is also gone - there's another gripe!), everything else seems to be working fine, except I'm still having trouble with K8U. It's all gone from PT11. They're not showing up in the plugin pull-down menus. (I assume this is because they're not the new AAX versions.) But now when I use the NI Service Center to try to get all the updates, they're gone from the "Updates" section anymore. I notice they're all in the "Activate" section (with most of the activation codes already filled in). But I presume these are the old RTAS ones meant for 10.3.8. And when I try and activate them, I get this error message: "Not activated - Internal error during activation procedure. (5)." The actual plugs show up in the 10.3.8 co-install, but when inserting one of them in one of those sessions, it makes me either buy it or run in demo mode. It doesn't seem to recognize the current activation. Do I need to somehow deauthorize them on my old computer first? (Not sure how to do that.) And how do I get the new updates back? They've disappeared from the NI Service Center altogether. I keep getting the same error message pretty much when I try to do anything there (tried several times now). Anybody else having similar issues? I've contacted NI for support, but no response yet. Thought I'd see if anyone here has any insight.
iMac 21.5" (2017) Intel Core i7 3.6GHz, 1TB SSD, 32GB RAM PreSonus Quantum 2 interface Mac OSX 10.15.6 Catalina 1 G-Drive Pro 4 TB 2 G-Drive 6 TB ProTools 2021.3.1 Melodyne 5 Soundtoys Bundle 5.3.2 Omnisphere 2.6.2 Massey L2007 Superior Drummer 2.3.2 Komplete 13 Ultimate |
Re: Ugraded to 11/10.3.8 co-install, Komplete 8 Ultimate, Hybrid gone
YOu made the hugest of mistakes when you used Migration Assassin (aka Assistant) to bring stuff over from your old install. MA was never meant to bring old programs over - just data. You're going to have to bite the bullet, reformat your hard drive and re-install everything from scratch. Yes - that means digging out your K8 dvd's and spending some quality time shuffling disks in and out of the drive. And if the new computer doesn't have an optical drive they're cheap enough to buy at your local Best Buy or whatever store like that you have in your area. Heck even Amazon sells them.
When you're done doing that start NI Service Center and more likely than not you'll have to update SC; it may well happen automatically but you should get a notice of that. You shouldn't have to de-authorize your old computer - you could ask over in the NI forums but be aware there's no forum for Komplete as such; you'd have to ask in one of the other forums and I'd try the one for Kontakt first. Oh yeah - forgot to mention this: when you do get everything authorized (if you really need to) be sure to save off to dvd or another hard drive the updates you download from NI. That's easy enough to do before you do the actual update because the plugins don't update on their own - you have to do that manually. I save all my updates off to dvd so I have them should the machine crash or I need to do a quick re-install as I don't keep my studio machine on the net. |
Likely just a reinstall from the U8 drive of the apps (not content) if your content is intact and on separate drives.
Each will need to relink their content but this goes much faster. Your only loss in 11 will be Battery3 for AAX is only with Battery4
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
But for Battery 3 he could run it inside Blue Cat MB7-2 or Patchwork in PT11. |
Thanks for the replies guys.
All in all, Migration Assassin seemed to work pretty well for me. I've done it before, when I got that last computer. No troubles at all that time (except I didn't have K8U then.) And this time there were quite a few more headaches (obviously this being one of them). But I think it's far less a headache than I'd be dealing with loading in everything from scratch (all my apps and all - and trying to keep all my preferences, etc.). Quote:
So what would be the process here? Do I uninstall K8U, then reinstall from the installation drive (I guess that would be to get all the apps back for the 10.3.8 coinstall?), then run the Service Center to get them all authorized, then install the AAX updates (I guess that would be for 11)? From DetroitT (Sorry, I don't know how to multi-quote from different posters): "Likely just a reinstall from the U8 drive of the apps (not content) if your content is intact and on separate drives." Yes, I have all the content on a separate drive, thank god. Again from DetroitT: "Your only loss in 11 will be Battery3 for AAX is only with Battery." Yes, that blows, but I was kinda figuring in that part at least. I'm planning to biting the bullet and upgrading to 4 on that one. Again, I have some custom presets (kits) on 3, do you know if it will retain those?
As far as custom presets I'd save those off to a thumb drive or such and then reinstall clean everything from the K8U hard drive. You got lucky before with Migration Assassin but not now. It's never a good idea to sue it to bring programs over as you never know what gremlins will come over onto a new system. You'll not find one person here who recommends using it for anything other than personal data. As far as procedure - wipe everything NI off your system drive. Repair permissions, reboot. Reinstall everything from the NI drive, do any authorizations, and then download and install any updates you get through Service Center. If there's any aax64 updates you'll get them through that except for as you know Battery 4. Something if you don't know about it is that Battery 4 drops most of the analog kits in Battery 3. But that was taken care of by a Battery 4 update that when run updates your old Battery 3 kits to work in Battery 4 no problem or workaround. Even without that particular update you can play Battery 3 kits in Battery 4; you just have to use the browser to do so. The update supposedly puts the old kits in the normal Battery 4 kit choice realm. |
Thanks about the multiquote thing, got it now.
Also, like I mentioned before, I got the AAX updates already (downloaded and grabbed them from NI Service Center on my old computer and loaded them onto the new computer via flash drive.) I can just use those installers for those updaters, right? (Instead of downloading and installing them from NI Service Center on the new computer - if they're even there.)
If you have the latest updates then you can just bring them over via flash drive and install them on the new machine. Of course you're going to have to have the new machine online long enough to do any authorizations for the new computer. If you having a co-install of PT10 and PT11 on your computer - if you haven't done so already - install the latest version of PT10 first and then install latest version of PT11. There's something in the way folders are created that if you do it the other way around you could have problems. |
So I went ahead and just did the uninstall/reinstall of all of K8U. Then I downloaded the updates again from the Service Center on the new computer and installed all those. It worked. It wasn't super easy, had to reinstall a couple things a couple times for it to take, but at least they all seem to have made it. All is now good in PT11.
And happy to report all of my custom presets are still there. Didn't even have to do anything. They must've just stuck around from not being completely wiped out when I did the uninstall. What a huge relief! Thanks for all your help. Things should be all good now.
A word of warning if you do decide at some point to get K9U - the SSL effect emulations in GR5 get stripped out and are provided as standalone effects in K9U. If you want to have them also in GR5 you have to get in touch with NI support and they should be able to help you out. |
How long does komplete 9 ultimate take to install? | Kinh | Virtual Instruments | 4 | 02-26-2014 06:18 PM |
Komplete 9 Ultimate install problems | musicman691 | Virtual Instruments | 5 | 01-06-2014 03:57 PM |
Komplete 8 Ultimate | tystick420 | Pro Tools 11 | 10 | 07-07-2013 02:28 PM |
Komplete 8 Ultimate | paldry | macOS | 1 | 12-06-2011 07:42 PM |
