Solo Safe Not Working in PT 12 nor 2018.1 [solved]
Hi there,
When you try to change a solo in a track to solo safe, you can not do it because it appears a little fader similar to a send fader, which by the way, you do not know what exactly change. Thanks Last edited by Aquic; 02-05-2018 at 04:49 AM. Reason: I found the solution to the problem |
[Solved] Solo Safe Not Working in PT 12 nor 2018.1
Hi again,
I found what was going on... I do not know why, my Solo Mode preferences has been changes to Pre Fader Listen, so I couldn't do any Solo Safe on any track. Now it's working correct in SIP Mode.
Mac Pro 3,5 Ghz 6-Core Intel Xeon E5. 64 GB 1866 Mhz DDR3. High Sierra 10.13.6 ProTools Ultimate 2019.5 Interfaces 3 x 192 I/O + 1 x Apogee Rosetta 800 Logic Audio 10.4 |
PT 2018.1 crashes on boot, 12.8.3 worked perfectly [SOLVED] | aklru | Windows | 5 | 01-30-2018 02:26 PM |
Anyone else missing trim plugin after 2018 upgrade? [solved] | ratava911 | Pro Tools 2018 | 4 | 01-30-2018 06:08 AM |
Can't Solo Tracks When Bussed To Aux Sends / Solo Safe is armed (Greyed Out) | adrianrobison | macOS | 5 | 11-19-2014 05:09 PM |
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) | charlottewrinch | macOS | 2 | 04-14-2012 05:32 PM |
Solo/Solo-Safe dilemma | xcevinx | Pro Tools 9 | 10 | 12-08-2010 07:12 AM |
