Pro Tools 9 native?
Am I getting this right?
A native system is one which doesn't require external hardware running cards and dsp to operate? So pro tools 9 is now native as can run off the host computer? Thanks |
Re: Pro Tools 9 native?
Yes, this is correct.
Pro Tools LE was always native but required the user to use one of Avid's qualified interfaces. The difference now is that the user can use almost any audio interface. |
Have you been able to run PT9 without the mbox2 (or whatever qualified interfaces)? I tried running it but I get "ProTools could not initialize current playback device. Please make sure device has been configured correctly"
You need a sound card that is ASIO compatible. If it is not... ASIO4all may work for you.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
I should've mentioned. Running on iMac 2.9Ghz 4GB RAM
Hold 'N' while Pro Tools is starting up. In the Playback Engine, you should be able to select your internal output.
It worked!! Thank you :)
Does HD native or native native disable plugins when monitoring inputs? | BasketCase | Pro Tools HDX & HD Native Systems (Mac) | 7 | 05-20-2013 08:48 AM |
legacy PCI-based Pro Tools system to Pro Tools|HD Native card program | cozy_man | Pro Tools HDX & HD Native Systems (Mac) | 8 | 10-28-2011 07:22 AM |
Pro Tools 9 Native vs Pro Tools 9 w/ Complete Production Toolkit | Heck | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 11-07-2010 08:12 AM |
The real difference between the new pro tools 9/HD native vs pro tools 7,8,9 HD!!! | endyo | Pro Tools 9 | 1 | 11-05-2010 09:21 PM |
SSL4000 native/ Renmaxx native/ DUY everpack native!!! | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-22-2007 07:58 AM |
