Old 09-17-2000, 08:07 AM
flyin dread flyin dread is offline
Default No SPDIF input for DIGI 001
I am running PT 5.0 w/ DAE 5.0.1
and when i go to setup/hardware spdif isnt even an option to choose from like you see in the manual.
G4/400/570ram PT LE
Old 09-18-2000, 06:36 AM
Mat Mat is offline
Default Re: No SPDIF input for DIGI 001
Do into your Hardware setup in PT and change your Digital option to ADAT and NOT S/PDIF. Then S/PDIF will be available.
Old 09-18-2000, 09:41 PM
thanx for your reply however, the digital option is not even displayed- ADAT is not an option either. any other ideas?
Old 09-19-2000, 04:07 AM
MichaelMacken MichaelMacken is offline
You need to access the Hardware Setup in the control panels, not from inside PT, then the options won't be greyed out....
if that's the problem
Old 09-19-2000, 05:02 AM
DigiTechSupt's Avatar
The only way to switch the Optical format within Pro Tools is in the Setups>Playback Engine>Other Options window.
Brent
Avid Audio Tech Support
Support FAQ
Digi 96io - can you mix Optical SPDIF and phono SPDIF? buckaroo Pro Tools TDM Systems (Mac) 1 08-24-2009 11:20 AM
Where is my SPDIF input? dubaifox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-16-2007 07:22 AM
SPDIF input Dropout on Digi 001? fingerz88d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-31-2005 11:09 PM
low spdif input and other q's: pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-09-2003 10:02 AM
Unable to monitor spdif input on digi 001 mix2much 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-29-2001 09:12 AM
