PT assertion + sys messsage but all runs well
I was in a final mix today fixing some things in the master with destructive punch, when this happened:
It was when clicking somewhere in a track, hit play.. Message: "an assertion error has occured" (or something similar, but no error code) Then the "usual" Mac OS Message "PT has encountered an error and must close". The strange thing is, PT was running fine after I had clicked away those messages and I could continue to work without restart! I have never had that one before. PT 7.4cs3 HD2 accel Mac Quad G5
http://felixrost.de |
Re: PT assertion + sys messsage but all runs well
That's probably not good idea to work through that.
I would 1. repair disk permissions 2. either clean uninstall/reinstall, or trash Digi Databases, DAE prefs and Pro Tools prefs keep other apps closed, airport/bluetooth off and see if you can keep from getting that again. |
Hello there,
There may be an assertion log posted for this that can help us fix the problem. Look for it by 1) Opening the Console (Applications->Utilities->Console), 2) then clicking Logs in the toolbar to expand the logs list 3) Expand the ~/Library/Logs folder 4) Look for "Pro Tools" in the list there, and expand it 5) Look for any logs under Pro Tools, click on them, then copy the contents which will appear in the right side of the window. If you find one, post it here, and I can have a look at it. We might be able to give you information on what caused it and how to avoid it by analyzing it.
Cheers, Paul Vercellotti Avid Engineering |
Thanks for the responses!
This error had never happened to me before. But what I was more stunned about is that PT ran fine after the OS message. That's usually a point of no return... I will post you the crash log when I get back to the system next week.
So this is the log from that day:
===== Darstellung beginnt beim Versatz 5304700 innerhalb der Datei mit der Länge 5435772. ==== ===== Über den Befehl „Neu laden“ im Menü „Ablage“ (Befehl-R) können Sie mehr darstellen. ==== ssage**, long long, bool (*)(Threads::Message const*), int, void**) + 1144 (icplusplus.c:28) 4 libCoreThreadsMac.dylib 0x1f5c150c Threads::Messaging::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 200 (icplusplus.c:28) 5 libCoreThreadsMac.dylib 0x1f5c38a0 Threads::Body::ThreadBody() + 48 (icplusplus.c:28) 6 libCoreThreadsMac.dylib 0x1f5ca424 Threads::ThreadImp::StarterFluid(void*) + 236 (icplusplus.c:28) 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 22: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 libCoreThreadsMac.dylib 0x1f5c3844 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long long, int, void**) + 348 (icplusplus.c:28) 3 libCoreThreadsMac.dylib 0x1f5c832c Threads::ThreadImp::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 1144 (icplusplus.c:28) 4 libCoreThreadsMac.dylib 0x1f5c150c Threads::Messaging::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 200 (icplusplus.c:28) 5 libCoreThreadsMac.dylib 0x1f5c38a0 Threads::Body::ThreadBody() + 48 (icplusplus.c:28) 6 libCoreThreadsMac.dylib 0x1f5ca424 Threads::ThreadImp::StarterFluid(void*) + 236 (icplusplus.c:28) 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 23: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 libCoreThreadsMac.dylib 0x1f5c3844 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long long, int, void**) + 348 (icplusplus.c:28) 3 libCoreThreadsMac.dylib 0x1f5c832c Threads::ThreadImp::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 1144 (icplusplus.c:28) 4 libCoreThreadsMac.dylib 0x1f5c150c Threads::Messaging::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 200 (icplusplus.c:28) 5 com.apple.carbonbundletemplate 0x244b9e60 PMDIODeviceControlRep::AVCReceiverThread() + 92 (bundle1.s:283) 6 libCoreThreadsMac.dylib 0x1f5ca424 Threads::ThreadImp::StarterFluid(void*) + 236 (icplusplus.c:28) 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 24: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 libCoreThreadsMac.dylib 0x1f5c3844 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long long, int, void**) + 348 (icplusplus.c:28) 3 libCoreThreadsMac.dylib 0x1f5c832c Threads::ThreadImp::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 1144 (icplusplus.c:28) 4 libCoreThreadsMac.dylib 0x1f5c150c Threads::Messaging::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 200 (icplusplus.c:28) 5 libCoreThreadsMac.dylib 0x1f5c38a0 Threads::Body::ThreadBody() + 48 (icplusplus.c:28) 6 libCoreThreadsMac.dylib 0x1f5ca424 Threads::ThreadImp::StarterFluid(void*) + 236 (icplusplus.c:28) 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 25: 0 libSystem.B.dylib 0x9000b4c8 mach_msg_trap + 8 1 libSystem.B.dylib 0x9000b41c mach_msg + 60 2 com.apple.CoreFoundation 0x907deba8 __CFRunLoopRun + 832 3 com.apple.CoreFoundation 0x907de4ac CFRunLoopRunSpecific + 268 4 com.apple.CoreFoundation 0x907ed90c CFRunLoopRun + 52 5 com.apple.AVCVideoServices 0x24e43b34 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServ icesThreadParams*) + 164 (AVCVideoServices.cpp:148) 6 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 26: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 libCoreThreadsMac.dylib 0x1f5c3844 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long long, int, void**) + 348 (icplusplus.c:28) 3 libCoreThreadsMac.dylib 0x1f5c832c Threads::ThreadImp::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 1144 (icplusplus.c:28) 4 libCoreThreadsMac.dylib 0x1f5c150c Threads::Messaging::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 200 (icplusplus.c:28) 5 com.avid.macflamethrowerohci 0x1ff3d4a8 (anonymous namespace)::FlamethrowerThreadedLinkManagerThread: :ThreadBody() + 168 (bundle1.s:283) 6 libCoreThreadsMac.dylib 0x1f5ca424 Threads::ThreadImp::StarterFluid(void*) + 236 (icplusplus.c:28) 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 27: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 libCoreThreadsMac.dylib 0x1f5c3844 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long long, int, void**) + 348 (icplusplus.c:28) 3 libCoreThreadsMac.dylib 0x1f5c832c Threads::ThreadImp::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 1144 (icplusplus.c:28) 4 libCoreThreadsMac.dylib 0x1f5c150c Threads::Messaging::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 200 (icplusplus.c:28) 5 libCoreThreadsMac.dylib 0x1f5c38a0 Threads::Body::ThreadBody() + 48 (icplusplus.c:28) 6 libCoreThreadsMac.dylib 0x1f5ca424 Threads::ThreadImp::StarterFluid(void*) + 236 (icplusplus.c:28) 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 28: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 libCoreThreadsMac.dylib 0x1f5c3844 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long long, int, void**) + 348 (icplusplus.c:28) 3 libCoreThreadsMac.dylib 0x1f5c832c Threads::ThreadImp::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 1144 (icplusplus.c:28) 4 libCoreThreadsMac.dylib 0x1f5c150c Threads::Messaging::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 200 (icplusplus.c:28) 5 libCoreThreadsMac.dylib 0x1f5c38a0 Threads::Body::ThreadBody() + 48 (icplusplus.c:28) 6 libCoreThreadsMac.dylib 0x1f5ca424 Threads::ThreadImp::StarterFluid(void*) + 236 (icplusplus.c:28) 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 29: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 libCoreThreadsMac.dylib 0x1f5c3844 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long long, int, void**) + 348 (icplusplus.c:28) 3 libCoreThreadsMac.dylib 0x1f5c832c Threads::ThreadImp::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 1144 (icplusplus.c:28) 4 libCoreThreadsMac.dylib 0x1f5c150c Threads::Messaging::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 200 (icplusplus.c:28) 5 com.apple.diopyromaniacohci 0x24c4d868 PMDIO_IOThreadBody::ThreadBody() + 88 (bundle1.s:283) 6 libCoreThreadsMac.dylib 0x1f5ca424 Threads::ThreadImp::StarterFluid(void*) + 236 (icplusplus.c:28) 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 30: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 libCoreThreadsMac.dylib 0x1f5c3844 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long long, int, void**) + 348 (icplusplus.c:28) 3 libCoreThreadsMac.dylib 0x1f5c832c Threads::ThreadImp::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 1144 (icplusplus.c:28) 4 libCoreThreadsMac.dylib 0x1f5c150c Threads::Messaging::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 200 (icplusplus.c:28) 5 libCoreThreadsMac.dylib 0x1f5c38a0 Threads::Body::ThreadBody() + 48 (icplusplus.c:28) 6 libCoreThreadsMac.dylib 0x1f5ca424 Threads::ThreadImp::StarterFluid(void*) + 236 (icplusplus.c:28) 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 31: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 libCoreThreadsMac.dylib 0x1f5c3844 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long long, int, void**) + 348 (icplusplus.c:28) 3 libCoreThreadsMac.dylib 0x1f5c832c Threads::ThreadImp::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 1144 (icplusplus.c:28) 4 libCoreThreadsMac.dylib 0x1f5c150c Threads::Messaging::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 200 (icplusplus.c:28) 5 libCoreThreadsMac.dylib 0x1f5c38a0 Threads::Body::ThreadBody() + 48 (icplusplus.c:28) 6 libCoreThreadsMac.dylib 0x1f5ca424 Threads::ThreadImp::StarterFluid(void*) + 236 (icplusplus.c:28) 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 32: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 libCoreThreadsMac.dylib 0x1f5c3844 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long long, int, void**) + 348 (icplusplus.c:28) 3 libCoreThreadsMac.dylib 0x1f5c832c Threads::ThreadImp::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 1144 (icplusplus.c:28) 4 libCoreThreadsMac.dylib 0x1f5c150c Threads::Messaging::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 200 (icplusplus.c:28) 5 libCoreThreadsMac.dylib 0x1f5c38a0 Threads::Body::ThreadBody() + 48 (icplusplus.c:28) 6 libCoreThreadsMac.dylib 0x1f5ca424 Threads::ThreadImp::StarterFluid(void*) + 236 (icplusplus.c:28) 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 33: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 libCoreThreadsMac.dylib 0x1f5c3844 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long long, int, void**) + 348 (icplusplus.c:28) 3 libCoreThreadsMac.dylib 0x1f5c832c Threads::ThreadImp::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 1144 (icplusplus.c:28) 4 libCoreThreadsMac.dylib 0x1f5c150c Threads::Messaging::WaitForThreadMessage(Threads:: Message**, long long, bool (*)(Threads::Message const*), int, void**) + 200 (icplusplus.c:28) 5 com.apple.diopyromaniacohci 0x24c08910 PMDIODeviceControlRep::AVCReceiverThread() + 92 (bundle1.s:283) 6 libCoreThreadsMac.dylib 0x1f5ca424 Threads::ThreadImp::StarterFluid(void*) + 236 (icplusplus.c:28) 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 34: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...ple.CoreServices.CarbonCore 0x90c04578 MPWaitOnSemaphore + 184 3 ...gn.framework.VideoEngineDIO 0x209380b8 SOCCreateObject.eh + 9508 4 ...gn.framework.CoreFoundation 0x02ac3bbc Sys_RawThreadTask::Run() + 108 5 ...gn.framework.CoreFoundation 0x02a70024 Sys_RawThread::GetCurrentThreadID() + 132 6 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 35: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...ple.CoreServices.CarbonCore 0x90c04578 MPWaitOnSemaphore + 184 3 ...gn.framework.VideoEngineDIO 0x2092a4fc SOCCreateObject + 26380 4 ...gn.framework.CoreFoundation 0x02ac3bbc Sys_RawThreadTask::Run() + 108 5 ...gn.framework.CoreFoundation 0x02a70024 Sys_RawThread::GetCurrentThreadID() + 132 6 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 36: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...gn.framework.VideoEngineDIO 0x2091bab8 dyld_stub_CFBundleGetMainBundle + 546257624 3 ...gn.framework.VideoEngineDIO 0x2091bbb0 dyld_stub_CFBundleGetMainBundle + 546257872 4 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 37: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...ple.CoreServices.CarbonCore 0x90c04578 MPWaitOnSemaphore + 184 3 com.digidesign.ProToolsHD 0x00d7a33c start + 14121964 4 ...gn.framework.CoreFoundation 0x02ac3bbc Sys_RawThreadTask::Run() + 108 5 ...gn.framework.CoreFoundation 0x02a70024 Sys_RawThread::GetCurrentThreadID() + 132 6 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 38: 0 libSystem.B.dylib 0x9001fa0c select + 12 1 com.tcltk.tcllibrary 0x9abe0818 NotifierThreadProc + 432 2 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 39: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...ple.CoreServices.CarbonCore 0x90c04578 MPWaitOnSemaphore + 184 3 com.digidesign.framework.DAE 0x03683b30 FicGetApplicationInterface + 234208 4 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 40: 0 libSystem.B.dylib 0x9000b4c8 mach_msg_trap + 8 1 libSystem.B.dylib 0x90108edc mach_msg_receive + 56 2 ...n.framework.PlatformSupport 0x045bd19c PSCPUTime_GetAbsoluteTicks(unsigned long long&) + 10408 3 ...n.framework.PlatformSupport 0x045c1768 PSHardware_Sync() + 14468 4 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 41: 0 libSystem.B.dylib 0x900412f8 mach_wait_until + 8 1 ...ple.CoreServices.CarbonCore 0x90bfdea4 MPDelayUntil + 60 2 ...gn.framework.CoreFoundation 0x02a36ccc Sys_AtomicInt32::Exchange(long) + 364 3 ...gn.framework.CoreFoundation 0x02ac3d58 Sys_RawThreadTimerTask::Exec() + 104 4 ...gn.framework.CoreFoundation 0x02ac3bbc Sys_RawThreadTask::Run() + 108 5 ...gn.framework.CoreFoundation 0x02a70024 Sys_RawThread::GetCurrentThreadID() + 132 6 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 42: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x90001d90 pthread_mutex_lock + 472 2 ...gn.framework.CoreFoundation 0x02a6e5e8 Sys_QueueForInterruptBase::~Sys_QueueForInterruptB ase [in-charge]() + 376 3 ...gn.framework.CoreFoundation 0x02ac3d8c Sys_RawThreadTimerTask::Exec() + 156 4 ...gn.framework.CoreFoundation 0x02ac3bbc Sys_RawThreadTask::Run() + 108 5 ...gn.framework.CoreFoundation 0x02a70024 Sys_RawThread::GetCurrentThreadID() + 132 6 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 43: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...gn.framework.CoreFoundation 0x02a6f6c8 Sys_RawSemaphorePthread::Acquire() + 200 3 com.digidesign.ProToolsHD 0x00eaed40 start + 15386096 4 com.digidesign.ProToolsHD 0x00eaf598 start + 15388232 5 ...gn.framework.CoreFoundation 0x02ac3bbc Sys_RawThreadTask::Run() + 108 6 ...gn.framework.CoreFoundation 0x02a70024 Sys_RawThread::GetCurrentThreadID() + 132 7 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 8 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 44: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...gn.framework.CoreFoundation 0x02a6f6c8 Sys_RawSemaphorePthread::Acquire() + 200 3 com.digidesign.ProToolsHD 0x00eaf258 start + 15387400 4 ...gn.framework.CoreFoundation 0x02ac3bbc Sys_RawThreadTask::Run() + 108 5 ...gn.framework.CoreFoundation 0x02a70024 Sys_RawThread::GetCurrentThreadID() + 132 6 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 45: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...ple.CoreServices.CarbonCore 0x90c04578 MPWaitOnSemaphore + 184 3 com.digidesign.ProToolsHD 0x00eabcf0 start + 15373728 4 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 46: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...gn.framework.CoreFoundation 0x02a6f6c8 Sys_RawSemaphorePthread::Acquire() + 200 3 com.digidesign.ProToolsHD 0x00eaed40 start + 15386096 4 com.digidesign.ProToolsHD 0x00eaf598 start + 15388232 5 ...gn.framework.CoreFoundation 0x02ac3bbc Sys_RawThreadTask::Run() + 108 6 ...gn.framework.CoreFoundation 0x02a70024 Sys_RawThread::GetCurrentThreadID() + 132 7 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 8 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 47: 0 libSystem.B.dylib 0x9000b4c8 mach_msg_trap + 8 1 libSystem.B.dylib 0x9000b41c mach_msg + 60 2 com.apple.audio.midi.CoreMIDI 0x96b75ac8 XServerMachPort::ReceiveMessage(int&, void*, int&) + 84 3 com.apple.audio.midi.CoreMIDI 0x96b68c80 MIDIInPortThread::Run() + 64 4 com.apple.audio.midi.CoreMIDI 0x96b6cf44 XThread::RunHelper(void*) + 28 5 com.apple.audio.midi.CoreMIDI 0x96b7687c CAPThread::Entry(CAPThread*) + 96 6 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 48: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...ple.CoreServices.CarbonCore 0x90bc6a2c MPWaitOnQueue + 224 3 ...gn.framework.CoreFoundation 0x02a365b8 Sys_AsyncMessageQueue::Sys_AsyncMessageQueue[not-in-charge]() + 440 4 ...gn.framework.CoreFoundation 0x02ac3bbc Sys_RawThreadTask::Run() + 108 5 ...gn.framework.CoreFoundation 0x02a70024 Sys_RawThread::GetCurrentThreadID() + 132 6 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 49: 0 libSystem.B.dylib 0x90023de0 recvfrom + 12 1 com.digidesign.ProToolsHD 0x00e0d664 start + 14724884 2 ...gn.framework.CoreFoundation 0x02ac3bbc Sys_RawThreadTask::Run() + 108 3 ...gn.framework.CoreFoundation 0x02a70024 Sys_RawThread::GetCurrentThreadID() + 132 4 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 50: 0 libSystem.B.dylib 0x900412f8 mach_wait_until + 8 1 ...ple.CoreServices.CarbonCore 0x90bfdea4 MPDelayUntil + 60 2 ...gn.framework.CoreFoundation 0x02a36ccc Sys_AtomicInt32::Exchange(long) + 364 3 ...gn.framework.CoreFoundation 0x02ac3d58 Sys_RawThreadTimerTask::Exec() + 104 4 ...gn.framework.CoreFoundation 0x02ac3bbc Sys_RawThreadTask::Run() + 108 5 ...gn.framework.CoreFoundation 0x02a70024 Sys_RawThread::GetCurrentThreadID() + 132 6 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 51: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...ple.CoreServices.CarbonCore 0x90c04578 MPWaitOnSemaphore + 184 3 com.digidesign.framework.DAE 0x03683b30 FicGetApplicationInterface + 234208 4 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 52: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...ple.CoreServices.CarbonCore 0x90c04578 MPWaitOnSemaphore + 184 3 com.digidesign.framework.DAE 0x03683b30 FicGetApplicationInterface + 234208 4 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 53: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...ple.CoreServices.CarbonCore 0x90c04578 MPWaitOnSemaphore + 184 3 com.digidesign.framework.DAE 0x03683b30 FicGetApplicationInterface + 234208 4 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 54: 0 libSystem.B.dylib 0x9000b4c8 mach_msg_trap + 8 1 libSystem.B.dylib 0x9000b41c mach_msg + 60 2 com.apple.CoreFoundation 0x907deba8 __CFRunLoopRun + 832 3 com.apple.CoreFoundation 0x907de4ac CFRunLoopRunSpecific + 268 4 com.apple.CoreFoundation 0x907ed90c CFRunLoopRun + 52 5 <<00000000>> 0x3e0e5b88 0 + 1041128328 6 <<00000000>> 0x3e0e386c 0 + 1041119340 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 55: 0 libSystem.B.dylib 0x900412f8 mach_wait_until + 8 1 libSystem.B.dylib 0x900410c4 nanosleep + 388 2 libSystem.B.dylib 0x90044898 usleep + 88 3 <<00000000>> 0x3e0e3c5c 0 + 1041120348 4 <<00000000>> 0x3e0e386c 0 + 1041119340 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 56: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...ple.CoreServices.CarbonCore 0x90c04578 MPWaitOnSemaphore + 184 3 ...gn.framework.VideoEngineDIO 0x20916adc dyld_stub_CFBundleGetMainBundle + 546237180 4 ...gn.framework.CoreFoundation 0x02ac3bbc Sys_RawThreadTask::Run() + 108 5 ...gn.framework.CoreFoundation 0x02a70024 Sys_RawThread::GetCurrentThreadID() + 132 6 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 57: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...ple.CoreServices.CarbonCore 0x90c04578 MPWaitOnSemaphore + 184 3 com.digidesign.framework.DAE 0x03683b30 FicGetApplicationInterface + 234208 4 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 58: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...ple.CoreServices.CarbonCore 0x90c04578 MPWaitOnSemaphore + 184 3 com.digidesign.framework.DAE 0x03683b30 FicGetApplicationInterface + 234208 4 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 59: 0 libSystem.B.dylib 0x9000b4c8 mach_msg_trap + 8 1 libSystem.B.dylib 0x9000b41c mach_msg + 60 2 com.apple.CoreFoundation 0x907deba8 __CFRunLoopRun + 832 3 com.apple.CoreFoundation 0x907de4ac CFRunLoopRunSpecific + 268 4 com.apple.CoreFoundation 0x907ed90c CFRunLoopRun + 52 5 <<00000000>> 0x43c12b88 0 + 1136733064 6 <<00000000>> 0x43c1086c 0 + 1136724076 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 60: 0 libSystem.B.dylib 0x900412f8 mach_wait_until + 8 1 libSystem.B.dylib 0x900410c4 nanosleep + 388 2 libSystem.B.dylib 0x90044898 usleep + 88 3 <<00000000>> 0x43c10c5c 0 + 1136725084 4 <<00000000>> 0x43c1086c 0 + 1136724076 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 61: 0 libSystem.B.dylib 0x9000b4c8 mach_msg_trap + 8 1 libSystem.B.dylib 0x9000b41c mach_msg + 60 2 com.apple.CoreFoundation 0x907deba8 __CFRunLoopRun + 832 3 com.apple.CoreFoundation 0x907de4ac CFRunLoopRunSpecific + 268 4 com.apple.CoreFoundation 0x907ed90c CFRunLoopRun + 52 5 <<00000000>> 0x4656ab88 0 + 1180085128 6 <<00000000>> 0x4656886c 0 + 1180076140 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 62: 0 libSystem.B.dylib 0x900412f8 mach_wait_until + 8 1 libSystem.B.dylib 0x900410c4 nanosleep + 388 2 libSystem.B.dylib 0x90044898 usleep + 88 3 <<00000000>> 0x46568c5c 0 + 1180077148 4 <<00000000>> 0x4656886c 0 + 1180076140 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 63: 0 libSystem.B.dylib 0x90131d98 semaphore_timedwait_trap + 8 1 ...n.framework.PlatformSupport 0x045c2174 PSHardware_Sync() + 17040 2 com.digidesign.mixer.stereo 0x1deed47c Dispatcher + 56888 3 ...n.framework.PlatformSupport 0x045c17a4 PSHardware_Sync() + 14528 4 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 64: 0 libSystem.B.dylib 0x900412f8 mach_wait_until + 8 1 ...ple.CoreServices.CarbonCore 0x90bfdea4 MPDelayUntil + 60 2 ...gn.framework.CoreFoundation 0x02a36ccc Sys_AtomicInt32::Exchange(long) + 364 3 ...gn.framework.CoreFoundation 0x02ac3d58 Sys_RawThreadTimerTask::Exec() + 104 4 ...gn.framework.CoreFoundation 0x02ac3bbc Sys_RawThreadTask::Run() + 108 5 ...gn.framework.CoreFoundation 0x02a70024 Sys_RawThread::GetCurrentThreadID() + 132 6 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 65: 0 libSystem.B.dylib 0x90055468 semaphore_timedwait_signal_trap + 8 1 libSystem.B.dylib 0x90071be8 pthread_cond_timedwait_relative_np + 556 2 ...ple.CoreServices.CarbonCore 0x90bf948c TSWaitOnSemaphoreCommon + 176 3 ...ple.CoreServices.CarbonCore 0x90bf92e0 AsyncFileThread(void*) + 56 4 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 0 crashed with PPC Thread State 64: srr0: 0x000000000089f4d0 srr1: 0x100000000000f930 vrsave: 0x0000000000000000 cr: 0x24082234 xer: 0x0000000000000000 lr: 0x000000000089f688 ctr: 0x0000000002f287e0 r0: 0x000000000089f64c r1: 0x00000000bfffe8c0 r2: 0x0000000000000000 r3: 0x000000004d330c00 r4: 0x000000004d330c00 r5: 0x00000000000003e8 r6: 0xffffffffffffffff r7: 0x0000000000000000 r8: 0x0000000000000001 r9: 0x00000000a0001fac r10: 0x0000000000000001 r11: 0x000000000157f08c r12: 0x0000000002f287e0 r13: 0x0000000000000002 r14: 0x0000000000000000 r15: 0x00000000a3297698 r16: 0x0000000001580000 r17: 0x0000000000fb0000 r18: 0x0000000000fb0000 r19: 0x0000000000000001 r20: 0x0000000001950000 r21: 0x0000000001580000 r22: 0x0000000001580000 r23: 0x0000000000000000 r24: 0x0000000001580000 r25: 0x0000000001580000 r26: 0x0000000000000001 r27: 0x000000004245ec00 r28: 0x000000004245ef98 r29: 0x00000000bfffe908 r30: 0x0000000000000000 r31: 0x000000004c8d8880 Binary Images Description: 0x1000 - 0x153afff com.digidesign.ProToolsHD 7.3.1cs5 (7.3.1f131) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/MacOS/Pro Tools HD 0x1ecc000 - 0x1ef9fff com.digidesign.framework.CFD 7.3.1cs5 (7.3.1f131) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/CFD.framework/Versions/A/CFD 0x1f0f000 - 0x1f27fff com.digidesign.framework.DMC 7.3.1cs5 (7.3.1f131) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/DMC.framework/Versions/A/DMC 0x1f37000 - 0x1fb4fff com.digidesign.framework.DSI 7.3.1cs1 (7.3.1f124) /Library/Frameworks/DSI.framework/Versions/A/DSI 0x1ff7000 - 0x1ffafff libFicClockComponent.dylib /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/libFicClockComponent.dylib 0x2808000 - 0x28e3fff libOMFToolkit.dylib /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/libOMFToolkit.dylib 0x2a05000 - 0x2b1ffff com.digidesign.framework.CoreFoundation 7.3.1cs5 (7.3.1f131) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/CFnd.framework/Versions/A/CFnd 0x2bab000 - 0x2d6ffff com.digidesign.framework.DFW 7.3.1cs5 (7.3.1f131) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/DFW.framework/Versions/A/DFW 0x2e6f000 - 0x325dfff com.digidesign.framework.FileFormat 7.3.1cs5 (7.3.1f131) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/FFmt.framework/Versions/A/FFmt 0x35de000 - 0x39fffff com.digidesign.framework.DAE 7.3.1cs4 (7.3.1f129) /Library/Frameworks/DAE.framework/Versions/A/DAE 0x3d09000 - 0x3eaefff com.digidesign.framework.DHS 7.3 (7.3f117) /Library/Frameworks/DHS.framework/Versions/A/DHS 0x3f01000 - 0x4234fff libNeoAccessPro.dylib /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/libNeoAccessPro.dylib 0x4300000 - 0x436dfff com.digidesign.framework.DirectIO 7.3.1cs4 (7.3.1f129) /Library/Frameworks/DirectIO.framework/Versions/A/DirectIO 0x45b5000 - 0x45d1fff com.digidesign.framework.PlatformSupport 7.3 (7.3f117) /Library/Frameworks/DigiPlatformSupport.framework/Versions/A/DigiPlatformSupport 0x45e3000 - 0x505cfff libil.dylib /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/libil.dylib 0x7a32000 - 0x7a92fff com.digidesign.framework.DUI 7.3 (7.3f117) /Library/Frameworks/DUI.framework/Versions/A/DUI 0x7aa7000 - 0x7afcfff com.digidesign.framework.DSPManager 7.3 (7.3f117) /Library/Frameworks/DSPManager.framework/Versions/A/DSPManager 0x7f76000 - 0x7feffff com.DivXInc.DivXDecoder 6.0.5 /Library/QuickTime/DivX 6 Decoder.component/Contents/MacOS/DivX 6 Decoder 0x8ff7000 - 0x9005fff com.apple.iokit.IOUSBLib 2.5.9 /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib 0x9722000 - 0x9749fff DigiMachOServices 7.3 (7.3f117) /Library/Frameworks/DigiMachOServices.framework/DigiMachOServices 0x97ed000 - 0x97eefff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin 0x1dc4d000 - 0x1dca8fff com.digidesign.plugin.DigiReWire 7.3 (7.3f117) /Library/Application Support/Digidesign/Plug-Ins/DigiReWire.dpm/Contents/MacOS/DigiReWire 0x1dcd2000 - 0x1dd3efff se.propellerheads.rewire.library 1.7 /Library/Application Support/Propellerhead Software/ReWire/ReWire.bundle/Contents/MacOS/ReWire 0x1ddc0000 - 0x1de38fff com.digidesign.plugin.SignalGenerator 7.3 (7.3f117) /Library/Application Support/Digidesign/Plug-Ins/Signal Generator.dpm/Contents/MacOS/Signal Generator 0x1deda000 - 0x1df3afff com.digidesign.mixer.stereo 7.3.1cs5 (7.3.1f131) /Library/Application Support/Digidesign/Plug-Ins/Stereo Mixer.dpm/Contents/MacOS/Stereo Mixer 0x1df74000 - 0x1dfd5fff com.digidesign.mixer.surround 7.3.1cs5 (7.3.1f131) /Library/Application Support/Digidesign/Plug-Ins/Surround Mixer.dpm/Contents/MacOS/Surround Mixer 0x1e1f1000 - 0x1e218fff com.digidesign.digidesign.DigiCoreAudioPlugIn 7.3cs1 (7.3f120) /Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin/Contents/MacOS/Digidesign CoreAudio 0x1f52d000 - 0x1f569fff com.avid.LavaFlow ??? (1.0) /Library/Frameworks/lavaFlow.framework/Versions/A/lavaFlow 0x1f5bf000 - 0x1f5d1fff libCoreThreadsMac.dylib /Library/Application Support/Avid/libCoreThreadsMac.dylib 0x1f5e3000 - 0x1f5e8fff libCoreUtils.dylib /Library/Application Support/Avid/libCoreUtils.dylib 0x1f705000 - 0x1f71afff AVX2PluginHost.dylib /Library/Application Support/Digidesign/Video Engine/AVX2/AVX2PluginHost.dylib 0x1f76f000 - 0x1f797fff libCoreServices.dylib /Library/Application Support/Avid/libCoreServices.dylib 0x1f905000 - 0x1f936fff libdigitalio.dylib /Library/Application Support/Avid/libdigitalio.dylib 0x1f96e000 - 0x1f988fff com.apple.IOFireWireLib 2.2.5 /System/Library/Extensions/IOFireWireFamily.kext/Contents/PlugIns/IOFireWireLib.plugin/Contents/MacOS/IOFireWireLib 0x1fb05000 - 0x1fb4bfff libMPEG2Parser.dylib /Library/Application Support/Avid/libMPEG2Parser.dylib 0x1fd05000 - 0x1fd97fff libSwrtFx.dylib /Library/Application Support/Avid/libSwrtFx.dylib 0x1ff05000 - 0x1ff55fff com.avid.macflamethrowerohci ??? (1.0) /Library/Application Support/Avid/MacFlamethrowerOHCI.bundle/Contents/MacOS/MacFlamethrowerOHCI 0x20105000 - 0x20182fff com.apple.carbonbundletemplate 1.0 /Library/Application Support/Digidesign/Video Engine/SharedSupport/AVX2_Plug-Ins/CodecManager.avx/Contents/MacOS/CodecManager 0x20905000 - 0x20939fff com.digidesign.framework.VideoEngineDIO 7.3.1cs3r3 (7.3.1f128) /Applications/Digidesign/Pro Tools/Video Engine/VideoEngineDIO.bundle/Contents/MacOS/VideoEngineDIO 0x20ae5000 - 0x20b08fff com.digidesign.framework.VeDioIF 7.3.1cs3 (7.3.1f126) /Applications/Digidesign/Pro Tools/Video Engine/VeDioIF.framework/Versions/A/VeDioIF 0x20bff000 - 0x216bafff il.dylib /Library/Application Support/Avid/il.dylib 0x23f8d000 - 0x23fa6fff MT.dylib /Library/Application Support/Avid/MT.dylib 0x24499000 - 0x24558fff com.apple.carbonbundletemplate 1.0 /Library/Application Support/Avid/DIOPyromaniac_v001.bundle/Contents/MacOS/DIOPyromaniac_v001 0x246e5000 - 0x24750fff com.avid.flamethrower.bundle ??? (1.0) /Library/Application Support/Avid/MacFlamethrower.bundle/Contents/MacOS/MacFlamethrower 0x24be9000 - 0x24ca7fff com.apple.diopyromaniacohci 1.0 /Library/Application Support/Avid/DIOPyromaniacOHCI_v001.bundle/Contents/MacOS/DIOPyromaniacOHCI_v001 0x24e34000 - 0x24e56fff com.apple.AVCVideoServices 1.0 (28) /Library/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices 0x253ca000 - 0x2543ffff com.avid.avx2.avidhost.avx2dll.avx2 avx2 version 1.0 (1.0) /Library/Application Support/Digidesign/Video Engine/SharedSupport/avx2.bundle/Contents/MacOS/avx2 0x256bb000 - 0x25804fff com.apple.carbonbundletemplate 1.0 /Library/Application Support/Digidesign/Video Engine/SharedSupport/AVX2_Plug-Ins/CMAvidDVCodec.avx/Contents/MacOS/CMAvidDVCodec 0x25a05000 - 0x25b18fff com.apple.carbonbundletemplate 1.0 /Library/Application Support/Digidesign/Video Engine/SharedSupport/AVX2_Plug-Ins/CMAvidJPEGCodec.avx/Contents/MacOS/CMAvidJPEGCodec 0x26905000 - 0x26a10fff com.apple.carbonbundletemplate 1.0 /Library/Application Support/Digidesign/Video Engine/SharedSupport/AVX2_Plug-Ins/CMAvidMPEG2IMXCodec.avx/Contents/MacOS/CMAvidMPEG2IMXCodec 0x2dae4000 - 0x2dae6fff com.digidesign.digiVOUTcomponent 7.3 (7.3f117) /Library/QuickTime/DigiVout.component/Contents/MacOS/DigiVout 0x2dc46000 - 0x2df42fff com.digidesign.plugin.AAFCOAPI 7.3.1cs5 (7.3.1f131) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/PlugIns/AAFCOAPI.bundle/Contents/MacOS/AAFCOAPI 0x2e097000 - 0x2e098fff com.digidesign.framework.OMFEnabler 7.3 (7.3f117) /Applications/Digidesign/Pro Tools/OMF.bundle/Contents/MacOS/OMF 0x2e2c0000 - 0x2e335fff com.digidesign.plugin.Dither 7.3 (7.3f117) /Library/Application Support/Digidesign/Plug-Ins/Dither.dpm/Contents/MacOS/Dither 0x32505000 - 0x32562fff com.digidesign.framework.HWC 7.3.1cs5 (7.3.1f131) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/HWC.framework/Versions/A/HWC 0x3318d000 - 0x332ccfff com.digidesign.personality.DCommand 7.3.1cs4 (7.3.1f129) /Applications/Digidesign/Pro Tools/Controllers/D-Command.bundle/Contents/MacOS/D-Command 0x341e1000 - 0x3427afff com.digidesign.plugin.Fela_Rack 7.3 (7.3f117) /Library/Application Support/Digidesign/Plug-Ins/Time Shift.dpm/Contents/MacOS/Time Shift 0x34504000 - 0x346a0fff com.digidesign.personality.DControl 7.3.1cs4 (7.3.1f129) /Applications/Digidesign/Pro Tools/Controllers/D-Control.bundle/Contents/MacOS/D-Control 0x3521c000 - 0x3529ffff com.digidesign.personality.Control24 7.3.1cs4 (7.3.1f129) /Applications/Digidesign/Pro Tools/Controllers/Control24.bundle/Contents/MacOS/Control24 0x3cc05000 - 0x3cd73fff com.Sony.PT7.OxfordDynamics 1.6 /Library/Application Support/Digidesign/Plug-Ins/SonyOxfordDynamics.dpm/Contents/MacOS/SonyOxfordDynamics 0x3d0ad000 - 0x3d155fff com.digidesign.plugin.Dynamics III 7.3 (7.3f117) /Library/Application Support/Digidesign/Plug-Ins/Dynamics III.dpm/Contents/MacOS/Dynamics III 0x3d405000 - 0x3d54cfff com.Sony.PT7.OxfordLimiter 1.4 /Library/Application Support/Digidesign/Plug-Ins/SonyOxfordLimiter.dpm/Contents/MacOS/SonyOxfordLimiter 0x3f820000 - 0x3f831fff com.digidesign.plugin.Invert-Duplicate 7.3 (7.3f117) /Library/Application Support/Digidesign/Plug-Ins/Invert-Duplicate.dpm/Contents/MacOS/Invert-Duplicate 0x3fbf2000 - 0x3fc31fff com.apple.QuickTimeFireWireDV.component 7.1.3 /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV 0x3fc3c000 - 0x3fcb5fff com.apple.applepixletvideo 1.2.5 (1.2d5) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo 0x42b49000 - 0x42ca2fff com.Sony.PT7.OxfordEQ 2.6 /Library/Application Support/Digidesign/Plug-Ins/SonyOxfordEQ.dpm/Contents/MacOS/SonyOxfordEQ 0x8fe00000 - 0x8fe52fff dyld 46.12 /usr/lib/dyld 0x90000000 - 0x901bdfff libSystem.B.dylib /usr/lib/libSystem.B.dylib 0x90215000 - 0x9021afff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib 0x9021c000 - 0x90269fff com.apple.CoreText 1.0.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText 0x90294000 - 0x90345fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x90374000 - 0x9072ffff com.apple.CoreGraphics 1.258.61 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x907bc000 - 0x90895fff com.apple.CoreFoundation 6.4.7 (368.28) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x908de000 - 0x908defff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x908e0000 - 0x909e2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib 0x90a3c000 - 0x90ac0fff libobjc.A.dylib /usr/lib/libobjc.A.dylib 0x90aea000 - 0x90b5cfff IOKit /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x90b72000 - 0x90b84fff libauto.dylib /usr/lib/libauto.dylib 0x90b8b000 - 0x90e62fff com.apple.CoreServices.CarbonCore 681.9 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x90ec8000 - 0x90f48fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x90f92000 - 0x90fd3fff com.apple.CFNetwork 129.20 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x90fe8000 - 0x91000fff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore 0x91010000 - 0x91091fff com.apple.SearchKit 1.0.5 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x910d7000 - 0x91100fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x91111000 - 0x9111ffff libz.1.dylib /usr/lib/libz.1.dylib 0x91122000 - 0x912ddfff com.apple.security 4.6 (29770) /System/Library/Frameworks/Security.framework/Versions/A/Security 0x913dc000 - 0x913e5fff com.apple.DiskArbitration 2.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x913ec000 - 0x91414fff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x91427000 - 0x91432fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib 0x91437000 - 0x9143ffff libbsm.dylib /usr/lib/libbsm.dylib 0x91443000 - 0x914befff com.apple.audio.CoreAudio 3.0.4 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x914fb000 - 0x914fbfff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x914fd000 - 0x91535fff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x91550000 - 0x91622fff com.apple.ColorSync 4.4.9 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x91675000 - 0x91706fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x9174d000 - 0x91804fff com.apple.QD 3.10.24 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x91841000 - 0x9189ffff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x918ce000 - 0x918effff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x91903000 - 0x91928fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent 0x9193b000 - 0x9197dfff com.apple.LaunchServices 182 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x91999000 - 0x919adfff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x919bb000 - 0x91a01fff com.apple.ImageIO.framework 1.5.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x91a18000 - 0x91adffff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib 0x91b2d000 - 0x91b42fff libcups.2.dylib /usr/lib/libcups.2.dylib 0x91b47000 - 0x91b65fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x91b6b000 - 0x91c22fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x91c71000 - 0x91c75fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x91c77000 - 0x91cdffff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib 0x91ce4000 - 0x91d21fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x91d28000 - 0x91d41fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x91d46000 - 0x91d49fff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x91d4b000 - 0x91e29fff libxml2.2.dylib /usr/lib/libxml2.2.dylib 0x91e49000 - 0x91e49fff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x91e4b000 - 0x91f30fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x91f38000 - 0x91f57fff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x91fc3000 - 0x92031fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x9203c000 - 0x920d1fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x920eb000 - 0x92673fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x926a6000 - 0x929d1fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x92a01000 - 0x92aeffff libiconv.2.dylib /usr/lib/libiconv.2.dylib 0x92af2000 - 0x92b7afff com.apple.DesktopServices 1.3.6 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x92bbb000 - 0x92de6fff com.apple.Foundation 6.4.8 (567.29) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x92f13000 - 0x92f31fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x92f3c000 - 0x92f96fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x92fb4000 - 0x92fb4fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x92fb6000 - 0x92fcafff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x92fe2000 - 0x92ff2fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x92ffe000 - 0x93013fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x93025000 - 0x930acfff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x930c0000 - 0x930cbfff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x930d5000 - 0x93102fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x9311c000 - 0x9312bfff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x93137000 - 0x9319dfff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering 0x931ce000 - 0x9321dfff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices 0x9324b000 - 0x93268fff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound 0x9327a000 - 0x93287fff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x93290000 - 0x9359efff com.apple.HIToolbox 1.4.9 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x936ee000 - 0x936fafff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x93773000 - 0x93773fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x93775000 - 0x93da8fff com.apple.AppKit 6.4.7 (824.41) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x94135000 - 0x941a7fff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x941e0000 - 0x942a4fff com.apple.audio.toolbox.AudioToolbox 1.4.5 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x942f6000 - 0x942f6fff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x942f8000 - 0x944b8fff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x94502000 - 0x9453ffff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib 0x94547000 - 0x94597fff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x945a0000 - 0x945b4fff com.apple.CoreVideo 1.4 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x9475d000 - 0x9476cfff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib 0x94774000 - 0x94781fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib 0x947c7000 - 0x947e0fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib 0x947e7000 - 0x94ab6fff com.apple.QuickTime 7.1.3 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime 0x94b79000 - 0x94beafff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib 0x94c5d000 - 0x94c7efff libmx.A.dylib /usr/lib/libmx.A.dylib 0x94fe6000 - 0x95003fff libresolv.9.dylib /usr/lib/libresolv.9.dylib 0x96b68000 - 0x96ba7fff com.apple.audio.midi.CoreMIDI 1.5 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI 0x96f8f000 - 0x96faefff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib 0x977b4000 - 0x977c1fff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL 0x98c76000 - 0x9962dfff com.apple.QuickTimeComponents.component 7.1.3 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents 0x99854000 - 0x99858fff com.apple.QuickTimeH264.component 7.1.3 /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264 0x9985a000 - 0x9993efff QuickTimeH264.altivec /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.altivec 0x99a8a000 - 0x99b51fff com.apple.QuickTimeMPEG4.component 7.1.3 /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4 0x9a46e000 - 0x9a48cfff com.apple.OpenTransport 2.0 /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport 0x9ab68000 - 0x9abf1fff com.tcltk.tcllibrary 8.4.7 1 /System/Library/Frameworks/Tcl.framework/Tcl ********** Host Name: administrators-power-mac-g5-2 Date/Time: 2008-04-09 17:16:38.190 +0200 OS Version: 10.4.9 (Build 8P135) Report Version: 4 Command: Pro Tools HD Path: /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/MacOS/Pro Tools HD Parent: WindowServer [55] Version: 7.4cs3 (7.4f320) PID: 175 Thread: 0 Exception: EXC_BAD_ACCESS (0x0001) Codes: KERN_INVALID_ADDRESS (0x0001) at 0x80000007 Thread 0 Crashed: 0 com.digidesign.framework.DFW 0x0302e1c8 CLongintIterator::~CLongintIterator [in-charge]() + 72 1 com.digidesign.framework.DFW 0x03043334 TApplication::ProcessEvent(TEvent*) + 52 2 com.digidesign.framework.DFW 0x03044be8 TApplication::WakeUp() + 104 3 com.digidesign.framework.DFW 0x030fc728 TApplication::GetApplicationVersionComponents(Cmn_ PolyVector<long, (bool)0>*) + 3064 4 com.apple.HIToolbox 0x93297934 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 692 5 com.apple.HIToolbox 0x9329708c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372 6 com.apple.HIToolbox 0x93296f08 SendEventToEventTargetWithOptions + 40 7 com.apple.HIToolbox 0x9329e2cc ToolboxEventDispatcherHandler(OpaqueEventHandlerCa llRef*, OpaqueEventRef*, void*) + 704 8 com.apple.HIToolbox 0x93297b84 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1284 9 com.apple.HIToolbox 0x9329708c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372 10 com.apple.HIToolbox 0x9329de90 SendEventToEventTarget + 40 11 com.apple.HIToolbox 0x932dec04 ToolboxEventDispatcher + 92 12 com.apple.HIToolbox 0x932deb90 HLTBEventDispatcher + 16 13 com.apple.HIToolbox 0x932dd148 RunApplicationEventLoop + 148 14 com.digidesign.framework.DFW 0x030e7590 DFW_EventLoop::RunApplicationEventLoop() + 16 15 com.digidesign.framework.DFW 0x030433ec TApplication::Run() + 60 16 com.digidesign.ProToolsHD 0x00ff5078 start + 16722072 17 com.digidesign.ProToolsHD 0x00002b0c start + 812 18 com.digidesign.ProToolsHD 0x00002810 start + 48 Thread 1: 0 libSystem.B.dylib 0x9000b4c8 mach_msg_trap + 8 1 libSystem.B.dylib 0x9000b41c mach_msg + 60 2 ...gn.framework.CoreFoundation 0x025d14bc catch_exception_raise + 348 3 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 2: 0 libSystem.B.dylib 0x9001fa0c select + 12 1 com.tcltk.tcllibrary 0x9abe0818 NotifierThreadProc + 432 2 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 3: 0 libSystem.B.dylib 0x9002f20c kevent + 12 1 com.apple.DesktopServices 0x92af4eb0 TFSNotificationTask::FSNotificationTaskProc(void*) + 56 2 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 3 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 4: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 ...ple.CoreServices.CarbonCore 0x90bc6a2c MPWaitOnQueue + 224 3 com.apple.DesktopServices 0x92af552c TNodeSyncTask::SyncTaskProc(void*) + 116 4 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 5: 0 libSystem.B.dylib 0x900c8370 sem_wait + 12 1 com.digidesign.framework.DAE 0x03d32ae4 FWMidiCallback + 479108 2 com.digidesign.framework.DAE 0x03d08478 FWMidiCallback + 305432 3 com.digidesign.framework.DAE 0x03d32bbc FWMidiCallback + 479324 4 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 6: 0 libSystem.B.dylib 0x900c8370 sem_wait + 12 1 com.digidesign.framework.DAE 0x03d32ae4 FWMidiCallback + 479108 2 com.digidesign.framework.DAE 0x03d08478 FWMidiCallback + 305432 3 com.digidesign.framework.DAE 0x03d32bbc FWMidiCallback + 479324 4 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 7: 0 libSystem.B.dylib 0x900c8370 sem_wait + 12 1 com.digidesign.framework.DAE 0x03d32ae4 FWMidiCallback + 479108 2 com.digidesign.framework.DAE 0x03d08478 FWMidiCallback + 305432 3 com.digidesign.framework.DAE 0x03d32bbc FWMidiCallback + 479324 4 ...ple.CoreServices.CarbonCore 0x90bc683c PrivateMPEntryPoint + 76 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 8: 0 libSystem.B.dylib 0x900412f8 mach_wait_until + 8 1 ...ple.CoreServices.CarbonCore 0x90bfdea4 MPDelayUntil + 60 2 ...ple.CoreServices.CarbonCore 0x90bfdcec Delay + 124 3 ...opellerheads.rewire.library 0x19a504b0 RWPUnregisterDeviceImp + 3096 4 ...opellerheads.rewire.library 0x19a88a08 RWPUnregisterDeviceImp + 233840 5 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 9: 0 libSystem.B.dylib 0x9001fa0c select + 12 1 com.apple.CoreFoundation 0x907f1434 __CFSocketManager + 472 2 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 10: 0 libSystem.B.dylib 0x9000b4c8 mach_msg_trap + 8 1 libSystem.B.dylib 0x9000b41c mach_msg + 60 2 com.apple.CoreFoundation 0x907deba8 __CFRunLoopRun + 832 3 com.apple.CoreFoundation 0x907de4ac CFRunLoopRunSpecific + 268 4 com.apple.audio.CoreAudio 0x9145863c HALRunLoop::OwnThread(void*) + 264 5 com.apple.audio.CoreAudio 0x914583dc CAPThread::Entry(CAPThread*) + 96 6 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 11: 0 libSystem.B.dylib 0x90131d98 semaphore_timedwait_trap + 8 1 ...n.framework.PlatformSupport 0x04545218 PSHardware_Sync() + 3416 2 com.digidesign.framework.DAE 0x03ceae10 FWMidiCallback + 185008 3 ...n.framework.PlatformSupport 0x04548848 PSHardware_Sync() + 17288 4 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 12: 0 libSystem.B.dylib 0x90131d98 semaphore_timedwait_trap + 8 1 ...n.framework.PlatformSupport 0x04545218 PSHardware_Sync() + 3416 2 ...n.framework.PlatformSupport 0x04556dc8 PSThreadTable_VerifyTableEntryExists(unsigned long) + 1608 3 ...gn.framework.CoreFoundation 0x025cd1a0 Sys_BlockingTimer:estroy(Sys_BlockingTimer*&) + 1328 4 ...gn.framework.CoreFoundation 0x025c26e8 Sys_RawThreadTimerTask::Exec() + 88 5 ...gn.framework.CoreFoundation 0x025c2880 Sys_RawThreadTask::Run() + 64 6 ...gn.framework.CoreFoundation 0x025cd784 Sys_RawThread:estroy(Sys_RawThread*&) + 340 7 ...n.framework.PlatformSupport 0x04548848 PSHardware_Sync() + 17288 8 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 13: 0 libSystem.B.dylib 0x90131d98 semaphore_timedwait_trap + 8 1 ...n.framework.PlatformSupport 0x04545218 PSHardware_Sync() + 3416 2 ...n.framework.PlatformSupport 0x04556dc8 PSThreadTable_VerifyTableEntryExists(unsigned long) + 1608 3 com.digidesign.ProToolsHD 0x00d59370 start + 13986704 4 ...gn.framework.CoreFoundation 0x025c2880 Sys_RawThreadTask::Run() + 64 5 ...gn.framework.CoreFoundation 0x025cd784 Sys_RawThread:estroy(Sys_RawThread*&) + 340 6 ...n.framework.PlatformSupport 0x04548848 PSHardware_Sync() + 17288 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 14: 0 libSystem.B.dylib 0x9000b4c8 mach_msg_trap + 8 1 libSystem.B.dylib 0x9000b41c mach_msg + 60 2 com.apple.CoreFoundation 0x907deba8 __CFRunLoopRun + 832 3 com.apple.CoreFoundation 0x907de4ac CFRunLoopRunSpecific + 268 4 com.apple.CoreFoundation 0x907ed90c CFRunLoopRun + 52 5 com.avid.flamethrower.bundle 0x1f06760c MFTCFRunLoopThreadBody::ThreadBody() + 76 (bundle1.s:283) 6 libCoreThreadsMac.dylib 0x1c6ddbc4 Threads::ThreadImp::StarterFluid(void*) + 236 (icplusplus.c:28) 7 libSystem.B.dylib 0x9002be88 _pthread_body + 96 Thread 15: 0 libSystem.B.dylib 0x9002c548 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x9003102c pthread_cond_wait + 480 2 libCoreThreadsMac.dylib 0x1c6d7b94 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long long, int, void**) + 360 (icplusplus.c:28) 3 libCoreThreadsMac.dylib 0x1c6e1e68 CoreThreadsMessageQueue::RemoveNext(Threads::Messa ge**, long long*, bool*, Threads::Message**, long long*, bool*, long long, int, void**, bool (*)(Threads::Message const*)) + 168 (icplusplus.c:28) 4 libCoreThreadsMac.dylib 0x1c6dbd64 Threads::ThreadImp::Wait
Error messsage. Please help!! | mixalotbass | Pro Tools M-Powered (Mac) | 1 | 06-26-2010 12:03 PM |
I NEED HELP With PRO TOOLS LE 7.3 ERROR MESSSAGE(806,164). | Yung Kole | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-11-2008 05:21 PM |
Importing MIDI file Help:Error messsage | joesas | MIDI | 0 | 02-13-2007 05:56 PM |
9093 interup messsage | reggaesly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-31-2007 11:35 AM |
Which Mp3 runs on OS X? | JimCutler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-04-2003 01:42 PM |
