Old 03-31-2008, 02:59 PM
Brandonx1 Brandonx1 is offline
Default using mac formatted disks with 7.4 drivers
Hi All,
Does anyone here use HFS+ disks to run sessions in PT 7.4. I just brought a esata drive that I formatted HFS+. I mix t my pc based 7.4 studio and layback at another studio with all mac PT rigs. My plain was to just work from one drive. bring that drive with me. I'm having soo much trouble with my rig when the drive is attached. Memory leak, drive not showing up after a restart, corrupt drive after that happens. searching the region bin takes about 5 mins a search, the relink window takes about ten min to open, ect. Without the drive, the rig doesn't have ay of these problems.
So, does anyone have this working well?
Best,
Brandon
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 03-31-2008, 04:30 PM
gibson_sg gibson_sg is offline
Default Re: using mac formatted disks with 7.4 drivers
What kind of system specs are you using and drive specs?
Also did you ever have any version of Mac Drive installed previously?
Old 03-31-2008, 11:34 PM
HI Gibson,
No, I've never have mac drive installed. I was actually thinking of trying mac drive 7 instead of the digi mac drive install. System in a roll my own rig with an HD 4 in it. The drive was a new g tech tb drive. Are you having good luck with mac drives used at session drives?
Best,
Brandon
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 04-01-2008, 12:02 AM
I have used them to run sessions in 7.3 and LE on occasion and remember it working, but initially that XP would bluescreen because I had some older 5.x version of Mac Drive installed along with Digi's HFS+ version of Mac Drive, whatever version they use. After uninstalling one or the other it started working.
Haven't tried since the 7.4 upgrade, but can try running a session all day tomorrow off an Oxford 911 HFS+ drive and will report back how it goes.
Are you on HD 7.4 on what flavor of XP?
Old 04-01-2008, 12:21 AM
Which eSATA drive -- I run MacDrive and it works flawlessly -- I'd suspect the eSATA connection before MacDrive.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-01-2008, 01:33 AM
mix109 mix109 is offline
Did you format the Drive on a MacPro or MacPPC?
If it was on a MacPro check if the partition scheme is the GUID one.
Try if possible to erase then in the partition TAB select option and select Apple Partition Map
If it not a hardware fault i would suspect the partition scheme
Old 04-01-2008, 02:52 PM
Rail
It's a g-tech drive.
Best,
Brandon
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
HD formatted for MAC ( HFS+ ) worked on my PC....THEN DID NOT ! oulablank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-18-2010 02:07 PM
"Native Support for Mac-Formatted HFS+ Disks on Windows XP"? Maskeeper Post - Surround - Video 2 09-19-2008 12:02 PM
Firewire formatted in OS-9 mavericksound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-18-2004 08:36 AM
How to tell if HD is formatted HFS or HFS+ Slideman Pro Tools TDM Systems (Mac) 3 09-25-2002 10:07 AM
New disks added, old disks audio files not loaded stevegalante Pro Tools TDM Systems (Mac) 3 05-14-2001 10:58 AM
