Old 03-18-2004, 10:37 AM
Voxer Voxer is offline
Default What\'s the deal w/ click-and-drag???
Most of the time when I click on a region to drag from the Regions List into a track, it doesn't take. I have to go back, click again (sometimes twice) to finally get it 'attached' to the mouse pointer and over into a track. This has been a problem since I started on ProTools 7 years ago. Doesn't matter which computer or version of PT.
Has this been a problem for you? Have you found a solution or work-around?
Thanks,
Dave
Old 03-18-2004, 10:58 AM
Bixby Bixby is offline
Default Re: What\'s the deal w/ click-and-drag???
Hmmm, I'm only using PTLE 6.x.
Sounds like you're in shuffle mode and you're not moving the mouse close enough to snap to the file?
Just an idea.
I have no problems with it.
Hope that helps-
Old 03-18-2004, 11:42 AM
Slim Shady Slim Shady is offline
I've always had the same problem as well, on countless numbers of ProTools rigs (my own at home, and several others at studios around town). I've just come to accept this as an inherent PT problem, I don't think there's anything that can be done about it.
Old 03-18-2004, 12:09 PM
Good to know I'm not the only one. Thanks, Slim.
Old 03-18-2004, 01:10 PM
Esteban Esteban is offline
hey, Voxer, same here, but it seems to happen more on stereo files than mono for some reason.
Hhhmmmmmm......sunspots????
Esteban.
PT LE 7.3, DV Toolkit, 2.26 Dual Intel, 2gig ram, OS 10.4.9
Click and drag for MIDI note trimming too sluggish mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 01-16-2022 03:23 PM
Modifier key to "click and drag" edit view around? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-20-2009 01:09 AM
can´t drag /drag and drop from DigiBase in 7 jofromabove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-28-2005 08:04 AM
ctrl+click/ drag not working !! please help!! shamelessnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-31-2004 09:02 AM
click and drag soundfile within region window? c-post Tips & Tricks 1 06-20-2001 02:06 PM
