RTAS Bypass During Recording
This can't be right...RTAS plugs enter bypass when the track on which the plug sits enters is record enabled. I swear this just started happening; I can't believe I've not used RTAS during recording in the past. Am I forgetting, or have I made some other error?
Thanks for straightening me out. John-
Pro Tools 2018.4 HDX, 192 and Lucid I/O 5,1 MacPro 12 Core; OSX 10.12.6 |
Re: RTAS Bypass During Recording
Normal. There's lots and lots of post on this from the past. Insert trim or a TDM plug-in first and RTAS will be activated during record.
I'm sure someone can explain the reasons for this or a search would pull it up, something to do with the architecture of how the mix buss works in TDM. |
you can also just put the rtas on a Aux input track and buss it to the record track
Expect delays when RTAS is being used while monitoring a input
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Thank you both. I'm embarrassed to have forgotten this. I'm attempting a new RTAS lifestyle over here...
John-
i m on PT6.4.1 TDM on a PC ans was having thw same problem, but PT wont lwt me put an rtas plugin after a TDMm it that a shortfall of 6.4 ?
yup, didn't start till 7.something.
e
ihatetyping |
Rtas Plugs Bypass | Siegfried Meier | Pro Tools TDM Systems (Mac) | 2 | 04-08-2007 01:49 PM |
RTAS are in BYPASS | Ron B | Pro Tools TDM Systems (Mac) | 1 | 09-30-2005 05:27 PM |
RTAS plug-ins go into bypass? | Cliffy_Boy | Pro Tools TDM Systems (Mac) | 5 | 05-26-2005 06:51 AM |
RTAS Plug-in in bypass | Eric R. Fischer | Pro Tools TDM Systems (Mac) | 3 | 02-19-2005 09:45 AM |
Help! RTAS Plug goes into bypass..... | Glitchmon | Pro Tools TDM Systems (Mac) | 1 | 02-17-2002 08:28 AM |
