Old 11-27-2011, 03:28 PM
ztaylor9632 ztaylor9632 is offline
Default Can Not UPDATE 8.0.4 to 8.0.5 Error Message
When i try to upgrade the installer on the update package says that it can not find a valid copy of pro tools installed on your computer. I purchased the mbox mini and it came with pro tools so i know its valid. How do i validate my copy or get the updater to recognize my copy of pro tools?
Thanks
Z
Work Dammit!
GIGABYTE GA-X58A-UD3R 1366 socket
i7 950 3.06 ghz quad core
8 gig 3x2 OCZ gold triple channel
Radeon HD5750 RT 1 gig
Barrucuda 1 Terabyte 7200 RPM SATA 3.0 gb/s
WD Black 1 Terabyte 7200 RPM SATA 6.0 gb/s
OS-Win 7 Home Premium
Pro Tools LE 8.0.4/Mbox Mini 3rd Gen
Old 11-27-2011, 03:29 PM
Default Re: Can Not UPDATE 8.0.4 to 8.0.5 Error Message
SiSoftware Sandra
Computer
Model : Gigabyte X58A-UD3R
Workgroup : WORKGROUP
Host Name : Beast
User : Zak T
Processor
Model : Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
Speed : 3.36GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing
Computer
Mainboard : Gigabyte X58A-UD3R
BIOS : Award (Phoenix) FE 12/23/2010
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 8GB DIMM DDR3
Chipset
Model : Giga-Byte X58 I/O Hub
Front Side Bus Speed : 2x 2.52GHz (5GHz)
Chipset
Model : Giga-Byte Core Desktop (Bloomfield) UnCore
Channels : 3
Memory Bus Speed : 2x 560MHz (1.12GHz)
Memory Module(s)
Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4)
Video System
Video Adapter : ATI Radeon HD 5700 Series (720 SM5.0 700MHz, 1GB DDR5 4x1.15GHz, PCIe 2.00 x16)
Graphics Processor
OpenCL Processor : ATI Radeon HD 5700 Series (720SP 9C 700MHz, 1GB 4x1.15GHz)
Compute Shader Processor : ATI Radeon HD 5700 Series (720SP 700MHz, 1010.4MB 4x1.15GHz)
Storage Devices
Seagate ST31000528AS (1TB, SATA, 3.5") : 932GB (C:)
WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) : 932GB (D:) (H:)
WD My Passport 070A 999.5GB (USB) : 931GB (I:)
ATAPI iHAS324 Y (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 7GB (E:)
Disk : N/A (F:)
WD Virtual CD 070A (USB) : 668MB (G:)
Logical Storage Devices
Komp (C:) : 932GB (NTFS) @ Seagate ST31000528AS (1TB, SATA, 3.5")
System (H:) : 100MB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ)
Music (I:) : 931GB (NTFS) @ WD My Passport 070A 999.5GB (USB)
Audio (D:) : 931GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ)
Pro Tools LE (E:) : 7GB (CDFS) @ ATAPI iHAS324 Y (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (F:) : N/A @ Disk
WD SmartWare (G:) : 615MB (UDF) @ WD Virtual CD 070A (USB)
Peripherals
LPC Hub Controller 1 : Giga-Byte LPC Interface Controller
LPC Legacy Controller 1 : ITE IT8720F
Audio Device : Giga-Byte HD Audio Controller
Audio Device : Pine Technology EG JUNIPER XT Audio Device [Radeon HD 5700 Series]
Audio Codec : ATI (AMD) HDMI Audio
Disk Controller : Giga-Byte 4 port SATA IDE Controller
Disk Controller : Giga-Byte 2 port SATA IDE Controller
Disk Controller : Giga-Byte 88SE91A3 SATA-600 Controller
Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller
USB Controller 1 : Giga-Byte USB UHCI Controller #4
USB Controller 2 : Giga-Byte USB UHCI Controller #5
USB Controller 3 : Giga-Byte USB UHCI Controller #6
USB Controller 4 : Giga-Byte USB EHCI Controller #2
USB Controller 5 : Giga-Byte USB UHCI Controller #1
USB Controller 6 : Giga-Byte USB UHCI Controller #2
USB Controller 7 : Giga-Byte USB UHCI Controller #3
USB Controller 8 : Giga-Byte USB EHCI Controller #1
FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : Samsung Universal Print Driver (600x600, USB, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Work Dammit!
Old 11-27-2011, 06:53 PM
zedhed's Avatar
zedhed zedhed is offline
Try right clicking the updater exe. and 'Run as Administrator'. Also disable any anti virus software.
I assume you are aware that you do not uninstall pro tools before running the updater. In the past some folks have assumed that the updater is actually a full installer when in fact it is...well...just an updater.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 11-28-2011, 08:02 AM
Good advice above. Here's a suggestion once you get it working again; remove one stick of RAM and install the other 3 sticks in 3 slots of the same color. That mobo is designed to run triple channel RAM and you may be hurting performance with 4 sticks(triple channel only works with either 3 or 6 sticks of identical RAM)
Old 11-28-2011, 11:51 AM
Thanks for the ideas. Tried the run as administrator, that did not resolve the issue. Still received the "Can not find a valid installation of pro tools on your system click "OK" to continue" error message.
In regards to the ram. Yes i realized this quite a while back and took out a stick of ram just havent updated my signature...guess i need to go do that...
Anyways the issue is with the updater not recognizing my installation of pro tools, cant figure out why...
Work Dammit!
Does anyone know what this error message means. ERROR DAE 9060 boabyd23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-18-2009 11:41 AM
A Message But Not An Error Message RichrdC Pro Tools M-Powered (Win) 3 01-27-2008 06:57 PM
TRYING TO UPDATE TO 6.9 - "AUTH CODE NOT VALID" MESSAGE GC101 Pro Tools TDM Systems (Mac) 7 03-17-2007 12:30 PM
Strange Error message with 6.9.2 LE CS2 update Digi2004 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-01-2005 09:52 AM
