loosing I/O\'s when I use a D24 on a MIX system
So, I have a system that runs fine with a mix core with two 888's and y cable on the core.
And it has two 888's on a y cable on a farm. 4 x 8 = 32 i/o If I add a d24 card the I/o's dissapear from the farm card and the primary driver becomes d24. #1 is there a way to make MIX the primary driver. #2 is there a way to not loose the I/O's on the farm card. #3 does it change based on the # of dsp's I select. Everything else runs perfect, xp2, 6.4.1 |
Re: loosing I/O\'s when I use a D24 on a MIX system
dump.
This should be an easy answer? digidesign? If I add the d24 card to the mix system, it doesn't allow me to use the I/O's on the mix farm, basically maxing the D24 useless. I thought it allowed more I/O's in this configuration... Does it allow more I/O's when used in a MAC? |
bump.
Digi? anybody? Does it do this in a mac? Anybody still using a mac hybrid? Can anyone remember this far back? I see no messages pertaining to this. Whenever I add the D24 to the system; The I/O's work, but I can't allocate the I/O's on 1 of the farm cards, Basically making the D24 useless, and not making it worth wild. My understanding is it's supposed to *add* two additional I/O's and let me continue to use my Farm's I/O's as well. |
Which slot order do you have the cards in the computer?
Forget that last question - the problem is that the D24 is not supported with anything higher than Pro Tools 6.1.
So does this mean if I use 6.1 that it will work properly and the I/O's will show up?
FWIW, I have tried every possible slot combination with the same result. |
Looks like AVID is loosing TC on AAX... | Fidelis | Pro Tools TDM Systems (Mac) | 11 | 10-23-2011 01:42 PM |
Loosing Tab to Transients | Mark Ziebarth | Pro Tools TDM Systems (Mac) | 2 | 09-22-2011 09:57 PM |
loosing MTC output | Pythagor | Post - Surround - Video | 0 | 02-13-2007 04:45 AM |
Loosing your SFX... | mark_corbin | Post - Surround - Video | 10 | 03-23-2003 09:52 PM |
Nuendo keeps loosing my 001 help!! | audio junkie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-19-2002 10:05 AM |
