Instrument and Click Track Question
I create an instrument track and a click track then record some simple notes through my keyboard. I quantize the notes to fit exactly with the metronome. After, I turn up the metronome from 120 bpm to 132 bpm. For some reason, the notes sync up with the metronome but not the track, so I go into the MIDI editor and move all of the notes to match up with the start of the track. But now that it matches with the track, it no longer is in sync with the metronome.
This problem is also even worse whenever I turn up the click by small increments. If I turn it up by 1 or 2 clicks it gets even worse to sync up and even worse to line up with the track. It is like the notes can’t line up with the track and the metronome at once and is something that has been bugging me since I’ve started a new beat. If this is something that you guys can fix that would be great. Thanks! |
Re: Instrument and Click Track Question
Check that the main ruler and counter are set to Bars|Beats and see if the grid lines up then.
Instrument tracks should have tick mode enabled by default so that clips follow tempo changes with the grid but double check to make sure the track didn't get switched to sample mode.
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory |
pop and click sounds with particular note-duration settings on instrument track | tendashi | Pro Tools 12 | 0 | 05-25-2016 11:19 AM |
question on using more than one Instrument track | UncleSamBand | Pro Tools 9 | 1 | 02-10-2012 06:48 PM |
Instrument Track Question | macr0w | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-20-2006 09:09 AM |
instrument track question... | phentalmyst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 04-20-2006 03:53 PM |
Instrument Track Question... | Wheeltard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-24-2006 11:02 AM |
