quicktime and feature length projects?
i'm about to begin post sound on a dv feature. i'm in need of suggestions on working with a broken up quicktime. (as an eighty minute quicktime is not possible, i believe) any suggestions or guidance on the best way to handle this would be greatly appreciated.
thanks |
Re: quicktime and feature length projects?
You're quite right about not being able to digitize 80 min worth of video, the problem being the Mac OS file size limit of 2 gig.I find I can digitize about 19 min of video on my fuse card at 1.5 meg/sec. If the show is longer (always) I just find a logical point near the 19 min mark, and begin the next capture.When importing the new movie, I simply spot it to the same timecode on the window burn. It's sort of a drag to have to import a new movie every 19 min., but I can see no other way.
[This message has been edited by Peter Steinbach (edited April 14, 2000).] |
Can you import more than one movie in PT5? (Can't be done in 4.x.)
Nope!
PT can only sync to one QTsource...right ? |
You actually can use movies bigger than 2 gig (os9 may support this already, can't remember). If the OS can't do it, you can combine multiple QT movies into a single one, just when you save the QT movie, use the "save normally (allowing dependencies)" option instead of "make self contained". Bingo.
Mike |
Originally posted by Ray Fabi:
Actually, I believe that with Adobe Prmiere 5.1 c, you can in fact create QT files that are larger than 2 GIG's. It automatically "pieces" together multiple 2 gig files... I have not tried it my self since at the moment I am working on half hour shows, but check it out with Adobe. I think you will get it to work! CIAO and good luck. ------------------ Ray Fabi Ton of Bricks Studios Montreal 514-990-2713 |
Feature request - selectable audio region fade in/out length | digidesigner | Pro Tools TDM Systems (Mac) | 7 | 04-21-2009 03:17 AM |
Quicktime Bounce - Name length limited | tj_davies | Pro Tools TDM Systems (Mac) | 2 | 06-20-2007 12:38 AM |
Canopus Quicktime Odd Frame Length? | The Cobbler | Post - Surround - Video | 2 | 09-30-2003 11:53 AM |
Feature Length Movie using Pro Tools | freudianslipper | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-20-2002 12:27 AM |
Setting up Session for feature-length Final Cot Pro project | Ray Chung | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-28-2002 01:12 AM |
