Maximum Allowed Activations
Hi everyone,
I have been running in circles trying to intall the expansion pack. Was not expecting such a roller coaster that has basically brought me to the point of completely re-installing windows. And, with good news I'm closer than I have ever been to getting mt 11R updated and that I haven't wasted $98.00. BUT, I am now looking at the "Please enter your Serial Number and SystemID" screen. I enter the information.... like I did before....when everything crashed. But since I did it before, now I get a message that reads "You have reached the maximum Allowed Activations for the Serial Number. Allowed seats:1 Currently Activated Seats:1 Attempted Amount:1 It's a "What's Next?!?!?" and a "SCREW THIS" kind of moment and really starting to get frustrated at the lack of foresight in where things might go wrong.... and things do. So when they do I wish AVID/DIGIDESIGN would point you in a direction that would eventually lead you to a solution. Like a "CLICK HERE to RESET YOUR ACTIVIATION or new ACTIVATION SERIAL NUMBER" ...or something...not just leaving you hanging only to leave you on your own posting a plee for help on an AVID user forum. Don't get me wrong Knowledge base is heaven sent.... what would we do with out each other? We'd all be lost! QUESTION" Is there a way to reset my seat count? Or dod I need to contact AVID ( who are probably close over the weekend so I'm screwed till Monday). What's with the limit anyways..... If you don't have the physical hardware ( i.e. the Eleven Rack) what good is this expansion pack anyways.... big brain-fart there. Thanks anyone for your help. NOTE: I did try downloading another "Eleven Rack Expansion Pack Installer Windows" download to see if it was fileID related.... didn't work. SPECS: WINDOWS 7 64-Bit PROTOOLS LE 8 ELEVEN RACK |
Re: Maximum Allowed Activations
That number was locked to that computer, and when you formatted, you erased all data that let the ERXP know that your computer is authorized.
You need to contact Avid. They must only allow it to be installed on one PC, if they did not, then someone could just give out or charge a reduced fee for a copy of the installer. Avid will take care of you, take a break, go grab a soda, have a smoke and relax for a bit. Im not sure when Avid will fix this for you, but they will. Eleven Rack Expansion Pack (ERXP) FAQ Also, once you have the Firmware updated to 2.0.1 you do need to ever run that part of the ERXP again, that is another reason it is locked.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Thanks.... I'm just venting.
They should automate this process. Not everybody has the time to wait I guess and it would free up their support team. |
Links to their support seems convoluted.... too many options.... any links available?
Tel: 650-731-6100 Fax: 650-731-6375 Monday - Thursday 8am-5pm PST, Friday 8am-4pm PST
A week? .. well that sucks.
no, i meant the rest of this week plus Monday since its a holiday.
So basically, when ever windows crashes and I have to re-install windows... which has coccured more than once in the last 6 months, I have to go through this serial # activiation release process from AVID each time?
Oh.... sure I get the holiday thing....
I did finally get the firmware updated so there is progress... now I just need to get the expansion pushed through... :) |
You can run the first part of the ERXP as many times as you want, on as many systems as you want. The first part of the ERXP only installs the updated GUI plugins so you can use the new ERXP items in Pro Tools. The second part, which is the firmware, only need to be run once, no matter how many times your PC crashes or if you change to a newer PC. Once the Eleven Rack is update, its updated.
more active audio tracks than the allowed maximum... | x0epikhigh0x | macOS | 2 | 12-10-2019 03:16 PM |
PSA: Slate VBC gives you two activations | mesaone | AAX Plug-ins | 3 | 02-15-2014 12:40 AM |
Maximum Allows Activations for ERXP | David2934 | Eleven Rack | 3 | 06-20-2011 07:39 PM |
Maximum Tracks Allowed/Pro Tools Mix System | unseen33 | Pro Tools TDM Systems (Win) | 1 | 02-15-2007 08:14 PM |
What's the maximum no of plugs allowed? | K.B. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-05-2004 07:50 PM |
