fYI 9600 os 9 and newer tech card.
Download newest revision of software from newer tech at their website. It seems to have ironed out some problems I was having. Since the download my system is running great(knock on wood).
Re: fYI 9600 os 9 and newer tech card.
Tell us, what problems were you having? We've got a 9600 w/Newer Tech. card and PT24 Mix plus running on OS8.6. Thinking of moving to OS9.
Very Interested. |
My system was crashing often. With midi and audio. At first it was a ram issue. The ram you have must be buffered and dampered. There is a thread on this with a link to the newer site. I took out the bad stick. I still had random freezes. I did a clean install of os 9 I reinitialized all my drives and reinstalled everything. Also use the minimun amount of extensions and I think aol sotware conflicted even though I did not have those extensions on in the digi set( It would freeze after being on aol and then going to pro tools). I have an ibm drive which did not have all the right jumper settings which was causing bus errors. Since I have done all these revisions to my system and upgraded to 5.01 and the newer download, I have'nt had one problem. I don't use aol anymore either. Although if 8.6 is working fine I would stick to that.This newer download is supposed to make the card be compatible with os9. It seems to work.So far very stable. Always defrag your drives too.
[This message has been edited by keysmia (edited July 30, 2000).] |
9600 w/ newer G4 freezing | houser | Pro Tools TDM Systems (Mac) | 4 | 10-16-2000 02:43 PM |
fYI 9600 os 9 and newer tech card. | keysmia | General Discussion | 1 | 07-28-2000 03:05 PM |
9600 and newer technolgy card. | keysmia | General Discussion | 6 | 02-23-2000 01:15 PM |
9600 001 and newer technology g3 400 mhz | keysmia | General Discussion | 3 | 02-21-2000 05:21 PM |
Newer 400/200 G3 card in a 9600 with PT tips? | Lee Blaske | Pro Tools TDM Systems (Mac) | 0 | 11-01-1999 05:47 PM |
